Turbo theory: Turbocharging a turbocharger...?
Don't flame yet. I'll explain as simply as I can.
What if you slapped a little T25 turbo going directly into a T66 compressor, would the T25 help spool the T66 in the low end, while the T66 would take over in the high end?
Obviosly the T25 would run out of breath, but by then the T66 is boosting away.
I KNOW it's not "possible" (physically) in a Honda, but remember: This is THEORY!
Re: Turbo theory: Turbocharging a turbocharger...? (tzsir)
same thing as rx-7 turbos... to an extend. They work sequentially... basically one powers the other.
only TT i can think of that doesn't operate liek this is the 300zx and 3000gt cars
Sorry to chime in on this, but if they can build a twin turbo I'm sure they can do a Bi-turbo.
Re: Turbo theory: Turbocharging a turbocharger...? (accordking)
The problem with that is you have two seperate spool times, on the rx-7 it is more prominent, but then again they are designed to be high speed touring cars...
Re: Turbo theory: Turbocharging a turbocharger...? (lazerus)
no...thats not how twin turbos work. If you run a smaller turbo into a big turbo, its just going to choke the smaller turbo. Also, a turbo spools on heat. At this time, all efficiency is lost.
Re: Turbo theory: Turbocharging a turbocharger...? (ninesecrx)
I had always thought that a Supra had 1 small turbo pumping boost into all 6 cylanders, as well as a larger turbo going into all 6 cylanders.
So which is it?
So which is it?
HT's Biggest Loser
Re: Turbo theory: Turbocharging a turbocharger...? (EpDarks)
Here is how a sequential setup works on an RX7...the same thing is probably also true of the MKIV since it is also a sequential TT.
At low speed, the exhaust passage that leads to the secondary turbo is closed by a valve, thus, only the primary turbo is operating. As the engine speed and load rise and the exhaust gas volume increases, a portion of the gas is directed towards the secondary turbo via a pre-spinning control valve to prepare it for full operation. Various parameters such as engine load, throttle opening and atmospheric pressure are calculated by a computer, which then determines the optimum moment to open the switching valve, hence, allowing the secondary turbo to start providing full boost.
This turbo arrangement enables the engine to respond briskly throughout the rev range and deliver exhilarating acceleration.
Re: Turbo theory: Turbocharging a turbocharger...? (BlueShadow)
well even at that, it doesnt help get the bigger turbo spooled like the question states. Also, the second turbo would have lag if its not running and then a bypass valve opens for it to operate...and your still going to have a bottleneck in the line.
The second turbo starts to get pre-spun by partial exhaust flow from the smaller turbo at lower RPMs, once the conditions are high enough the valve fully opens and allows the second turbo to fully spool. The second turbo doesn't just fully engage, it is pre-spun first.
I see...well to answer the original poster, the answer is no. With some thought involved, you might be able to make something work...kinda what you were thinking. What im wondering though is how they would switch from one to the other and how does it do this? I mean...does the smaller turbo not get exhaust once its reached its peak because it will still be a bottle neck once it ran out.
I dont remember exactly what RPM the larger turbo starts its pre-spool (valve opens a little, SOME gasses going to secondary turbine) and when it starts fully spooling (valve is open, letting ALL exhaust gasses through secondary turbine).
The at higher RPMs when the larger turbo starts spooling, the smaller turbo is still spooling and it will do so the whole time. And yes that smaller turbo does end up being a restriction. But as far as switching back and forth between small + large turbo to just the small turbo, I'm assuming that once you let off the throttle or the RPMs go down, the valve that lets exhaust gasses pass from small turbine to large turbine partially closes to let some exhaust gasses through or it closes completely to cut off all the exhaust gas to the larger turbine.
EDIT: in short: the small turbo will always be spooling, the larger turbo only spools above 3000-4000ish RPM.
[Modified by BlueShadow, 2:38 AM 1/15/2003]
yeah, must be hooked up on some sort of pressure valving or something. Pretty cool idea but it does have some flaws but with added advanges. The flaws I see is your going to get top hp because the smaller turbo backs up, more parts and cost that could go wrong...put for a guy who likes to have the power down low and top..this would work pretty cool.
[Modified by BlueShadow, 3:47 AM 1/15/2003]
Putting two turbos in series is what a turbojet is... might want to netsearch on turbojets and pulsejets. Nye Engineering used to have a nice site with a lot of DIY info, but it's currently under construction.
Good idea, impractical for an automotive engine. The heat involved would slag the engine.
Re: Turbo theory: Turbocharging a turbocharger...? (J. Davis)
What I meant by twin turbo was done so this is possible is the whole space and fitment issue DRT did it. This can be done without any valves or wastegates at all if properly sized and actual flow taken into account. I'm amazed at how many people like to make things nore complex than they really need to be. You would only need one wastegate to bypass the smaller turbo because the bigger turbo would never reach it's peak if you size it the right way.
The RX-7's set-up are convert to twin because the complexity of their particular set-up caused them a lot of problems, and troubleshooting these problems became difficult because of this complexity. It had nothing to do with it not working right. If someone actually sat down and fixed every problem that ran beautifully, but who would sit down and look at all those vacuum lines without going insane? Supra owner are after then peak power generally so they don't care if they have lag.
so u would place a wastegate with a smaller spring with the smaller turbo?
then when the wastegate dumps, it feeds to the larger turbo which has it's own wastegate?
is that how sequential turbos work?
The RX-7's set-up are convert to twin because the complexity of their particular set-up caused them a lot of problems, and troubleshooting these problems became difficult because of this complexity. <u>It had nothing to do with it not working right.</u>
The RX7's vacuum setup is complex and far from perfect and because of that complexity, it is hard to diagnose a simple vacuum leak from one of the many hoses coming loose. By getting rid of all those vacuum lines (the "Rats Nest") and going with a non-sequential setup they get rid of a lot of potential vacuum problems and make the system a lot less complex.
Ok sorry if I didn't makes sense there, but the reason they went wth sequential is because (those of you that have driven rotaries know this) rotaries make next to nothing for power down low so they needed a "boost" if you will to help them climb the rpm band quicker. Especially since the third gen RX-7 weighed a ton compare to the previous two generations. So came the sequential set-up.
This set-up was far from perfect in the first three years of it's run, but by it's fourth year they had it down to where vacuum leaks were almost non-exsistent in the factory set-up. Reasoning to convert after from the factory would normally be for easier troubleshooting when you have a problem obviously, or to increase the power drastically with-out risking a vacuum leak with higher boost. At first most people switched it over to twin, but a few people upgraded the sequential for a lagless drive.
I can read the entire book to you if you wish. That was a brief summary of the 3rd gen. Unfortunatelly we didn't get that fourth year becaus America was going through it's muscle car revival. Mainly due to the fact all the big sports cars then were Japanese, and this is the birthplace of the sports car(supposedly).
EDIT: the 3rd Gens actually weight less than the 2nd Gens because of all the lightweight stuff they had in there. (IE. drilled pedals to reduce weight).
They went with a larger secondary turbo to give it a higher peak HP. The reason most production cars have smaller sized turbos is to give the driver the impression that the car is fast by improving its low end response. The RX7 does that with the smaller turbo, and the larger turbo enables the RX7 to have it's higher peak HP.
[Modified by BlueShadow, 8:08 PM 1/15/2003]
