Problem with my MOTOR possibly a nitrous problem, please help!!!
Old Jan 14, 2003 | 03:23 PM
showlude's Avatar
Default Problem with my MOTOR possibly a nitrous problem, please help!!!
I got a 2001 Prelude SH with AEM CAI, ZEX colder plugs, and 55 shot DRY, I also got axel back duals mufflers so I have little back pressure, or less at least. My motor feels like its struggling in vtec when I push it nor does it feel to pull as hard, when Im not on the nitrous and I dont really notice it when I am on the nitrous but it doesnt seem to pull as hard either. I dont know whats wrong, I havent been spraying for more than a month, but I have sprayed like 3 times in a row on occasions like twice. Thanks Do you think its due to the nitrous? I DO
Old Jan 14, 2003 | 03:36 PM
BudaKai's Avatar
Default Re: Problem with my MOTOR possibly a nitrous problem, please help!!! (showlude)
Do a leakdown test. Check your coolant for oil.
Old Jan 14, 2003 | 03:38 PM
showlude's Avatar
Default Re: Problem with my MOTOR possibly a nitrous problem, please help!!! (tzsir)
can you explain what a leakdown test is, and what does check your coolant for oil mean
Old Jan 14, 2003 | 03:40 PM
rjardy's Avatar
it means that it sounds like you blew a head gasket or worse. Do a compression check
Rob
Old Jan 15, 2003 | 07:27 AM
showlude's Avatar
Default Re: Problem with my MOTOR possibly a nitrous problem, please help!!! (rjardy)
ttt
Old Jan 15, 2003 | 07:49 AM
Finest's Avatar
Do a compression test first. It'll clue you in if it's an internal problem, or some other problem.
It could be a number of things. Preludes have weak ringlands, so you might have blown that. Do you get any black/gray/white smoke out of the exhaust?
Or it could be as simple as a worn out clutch. (Let's hope it's just the clutch and not a costly engine rebuild)
j0keefe21
Jan 4, 2010 06:50 PM
jokerpimp
Apr 4, 2006 05:49 AM
NOSED_CRX_VTEC
Jan 3, 2003 02:01 PM
Dupes
Jul 8, 2002 02:43 PM
