check out this flow!!
Old Jan 13, 2003 | 07:08 AM
spun Vtec's Avatar
Default check out this flow!!
how bad is this?? i thought an hf manafold was bad.....
Old Jan 13, 2003 | 07:26 AM
xci_ed6's Avatar
Default Re: check out this flow!! (4gsicivichatch)
110% Hilarious.
-Dustin
Old Jan 13, 2003 | 07:37 AM
PrecisionH23a's Avatar
please tell me that's a heat shield....
Old Jan 13, 2003 | 07:51 AM
spun Vtec's Avatar
Default Re: check out this flow!! (GudeH23a)
hahaha no im afraid not
Old Jan 13, 2003 | 07:52 AM
spun Vtec's Avatar
FYI THIS IS IN NO WAY MY CAR!
i found it wile searching the net.
Old Jan 13, 2003 | 07:56 AM
Pelican's Avatar
Are you kidding? That thing will out-flow the Full-Race Manifold any day
Hilarious
Old Jan 13, 2003 | 07:57 AM
Hayasa15's Avatar
Can i get that in stainless?
Old Jan 13, 2003 | 08:02 AM
BudaKai's Avatar
Default Re: check out this flow!! (Hayasa15)
HAHAHAHA it's going to melt at the corners if it's ran too hard. Trust me squares and heat don't agree.
Can we say Ghetto?
[Modified by tzsir, 11:03 AM 1/13/2003]
Old Jan 13, 2003 | 08:03 AM
integra_gsr98's Avatar
I can't believe someone took the time to fab that! I wonder what it weighs in and of itself...
Old Jan 13, 2003 | 08:05 AM
vtec.dc2's Avatar
Default Re: check out this flow!! (tzsir)
http://www.apc-turbo-nos.com/newproducts/manifolds/
Old Jan 13, 2003 | 08:13 AM
spun Vtec's Avatar
Default Re: check out this flow!! (vtec.dc2)
y0
Old Jan 13, 2003 | 08:29 AM
BorderM3's Avatar
That is a classic...
Old Jan 13, 2003 | 08:33 AM
bgod's Avatar
Default Re: check out this flow!! (BorderM3)
i've seen budget turbo systems before on hondas, but this takes it.
gotta love the superman theme on the valve cover.
Old Jan 13, 2003 | 09:35 AM
rondigs's Avatar
Default Re: check out this flow!! (bgod)
LOL!
Just a little turbulence in there.
Old Jan 13, 2003 | 09:51 AM
2K_TEG's Avatar
Default Re: check out this flow!! (rondigs)
i am actually curious what kind of power that thing puts down. That is damn ugly.
Old Jan 13, 2003 | 10:00 AM
Crazy Cooter's Avatar
Default Re: check out this flow!! (2K_TEG)
Somebody needs a port job.
Old Jan 13, 2003 | 10:07 AM
willyboyK20's Avatar
Default Re: check out this flow!! (asdewq)
forget a port job, it needs more ports
[Modified by willyboyD16, 2:07 PM 1/13/2003]
Old Jan 13, 2003 | 10:12 AM
paulzy's Avatar
Default Re: check out this flow!! (willyboyD16)
hahahaha
Old Jan 13, 2003 | 10:35 AM
turbod16y8's Avatar
Default Re: check out this flow!! (1320development)
hey that is my car who post it on here
hahah yea rite JK
[Modified by turbod16y8, 7:36 PM 1/13/2003]
Old Jan 13, 2003 | 10:50 AM
ijjz's Avatar
Default Re: check out this flow!! (turbod16y8)
Can not believe someone would waste thier time with this.
Old Jan 13, 2003 | 11:21 AM
MaxBoost's Avatar
New User
Default Re: check out this flow!! (ijjz)
Things like this are great for lightning the mood in the FI forum...lol
Old Jan 13, 2003 | 12:03 PM
Joseph Davis's Avatar
Default Re: check out this flow!! (MaxBoost)
I really don't see much difference between it and a log style manifold, if you went to the trouble of sandwiching a thick ~1/2" flange with some transition-to-plenum porting. In theory, the longer exhaust "port" created by the log manifold helps out with anti-reversion, but with no comparison dynos you can't really tell how much good it does. As soon as you hit the log, *turbulence*.
Both a log style and that... interesting creation... are constant pressure designs. Good for low boost, not what you get your peak power from.
Old Jan 13, 2003 | 12:25 PM
Tinker219's Avatar
This is DIY gone wrong...
Old Jan 13, 2003 | 01:47 PM
BudaKai's Avatar
Default Re: check out this flow!! (J. Davis)
What you say makes sense, but that whole flat wall thing that's at the end of the exhaust flow creates even more turbulance & thus focusing the already high heat situation into a very nasty flow and unequal pressure problem that would cause cracks sooner than if with a log. with all this I'd say it would probably spool very quickly then fall on it's face until the wastegate opened to relieve some of the pressure. Either way a very bad idea. At least a log style trys to speed alond the flow with rounded ducting. It appears to be stainless too so there goes durabilty. I hope that made sense.
cdownin
Welding / Fabrication
11
Mar 19, 2010 03:14 PM
Da K00l Aid Mayun
Apr 20, 2005 03:31 PM
RACEPAK
Aug 1, 2004 03:01 PM
austrian type-R
Apr 14, 2004 10:11 AM
crx_ef8
Mar 1, 2003 06:50 PM
