Battle of Widebands? FJO or Techedge?
I have been researching and i cannot find out which wideband is better. I currently have Hondata in a Greddy Si Turbo kit. I want to get a wideband for tuning and just to see what my A/F Ratio is while driving.
On hondata's website they use the FJO for wideband tuning. But i remember a while back people were having issues hooking up the Techedge to the Hondata for the logging purposes. I might be switching over to AEM for the auto-tuning, but right now, i am sticking with what i have. Does the FJO have any better features than the Techedge? I dont think so. The only difference is the cost, correct?
Thanks in advance.
-deepsi
Thanks in advance.
-deepsi
Re: Battle of Widebands? FJO or Techedge? (DeepSi)
A friend of mine has Hondata with the Techedge, although it does not communicate with the ecu.
Another friend of mine has a Hondata with the FJO that is able to communicate with the ecu.
The main purpose of purchasing the FJO is to have the ability to connect it with the Hondata. Both units work fine, I have seen them. It all comes down to what you want? I do believe Techedge is comeing out with some software that will allow the ecu to log while the AFR, but it's not compatable with the Hondata or AEM.
Also you will not be able to Autotune with the Techedge!!!! So it comes down to what you want!
David.
David.
What is this crap?
Re: Battle of Widebands? FJO or Techedge? (turbo Si)
whats the issue with connecting the techedge to hondata?
it cant be that bloody difficult. i wonder if its a voltage skew issue, and hondata is configured only to work with the FJO output?
the new techedge v1.5 might address this sort of issue. i know the v1.0 has nonlinear output vs a/f....
Re: Battle of Widebands? FJO or Techedge? (falc0n)
If I had cash to burn I would get FJO, like David!
I will be buying a Techedge. I have been trying to figure out how EXACTLY to hook it to my Hondata, and I think I have. You have to run a wire from the display connector (from Turismo and racerxadam, http://www.techedge.com.au/vehicle/wbo2/info5301.htm) to the factory O2 signal pin.
You should be able to make the 1.5 work as your stock O2 by running another wire from the Data Acquisition port (pin 3, orange http://www.techedge.com.au/vehicle/wbo2/1v5/const.htm) to your stock O2 signal pin.
Then to run open or closed loop you just need to switch wires. Kinda sucks but affordable.
David.
David.
i use techedge v1 and hondata and it works perfectly its soo simple to hook up jsut follow the digram's on the hodnata website + get a old o2 sensor plug.
What is this crap?
Re: Battle of Widebands? FJO or Techedge? (BLKCRX)
I just remember from a long time ago, that when people put in the values for the Lamba, it would always forgot the values or the values or always off. I remember Dustin having these problems.
Re: Battle of Widebands? FJO or Techedge? (ladysman)
This has been fixed in V3 of the hondata software.
Hondata systems will work with any wideband that outputs a 0-5V signal proportional to airfuel-ratio.
anyone know how long it takes techedge too send you a money request(too pay via paypal)..i placed my order and am still waiting...they e-mailed me back saying they could ship next week..but never sent me apaypalk request like they are supposed too..anyone know how long? thnx
Re: Battle of Widebands? FJO or Techedge? (GOLDBERG)
Is this what comes with the v1.5 kit?Is this all thats needed?It said the cable to sensor and sensor itself not shown,but it is included correct?
Image above shows from left - Data Access cable, version 1.5 TE-WB unit and the TE-5301 display. Not shown is the cable to the sensor, and the sensor itself.
Should i just get the just this:
V 1.5 Package Deal 4.0 - TE-WB Unit with 4.0 m (~13') sensor cable and data acquisition cable & TE-5301 display (saving of $20).U.S. $330
Then all i have to do is get the actual sensor correct?
[Modified by J2turbo21, 9:11 AM 1/22/2003]
Re: Battle of Widebands? FJO or Techedge? (J2turbo21)
you are correct.... but the sensor is back order everywhere arggggg I'm trying to find one myself.....
for the guy who hasn't received his paypal request... email techedge I did and mine cmae through and is getting shipped this week...
Re: Battle of Widebands? FJO or Techedge? (LJR-LUDE01)
Re: Battle of Widebands? FJO or Techedge? (keebler65)
whats wrong with napa???says 139 on there website and ships in 24 hours???also not 300 like likespartsbin last time i checked
Why anyone would get the FJO over the Techedge is beyound me..... would you rather spend $291 and then say $130 for a total of $421 for a complete wideband setup? Or would you rather pay $700+.....
Since its understood BOTH work with hondata..... I don't see the arguement here at all anymore Tech-edge all the way, I love it.
Why don't you guys try your local Honda dealer. Just call them and ask for part# 36531-P07-003. I got mine for 140$ in just two days.
