ls headgasket
Old Jan 13, 2003 | 02:35 PM
redteg's Avatar
Default ls headgasket
i am running a 98 ls. i have the head off and i was wondering if i should use a stock honda gasket which leaves the compression ratio at 9.2.1 or should i use a cometic on which leaves it at 9.0.1. and waht else do i need to run 8 pounds of boost daily. safely. can it be done on stock internals and still be able to get good life out of the motor.
Old Jan 13, 2003 | 03:03 PM
turbohonda's Avatar
Default Re: ls headgasket (redteg)
Stick with the stock gasket. Lowering your compression .2 isn't going to affect much at only 8lbs of boost, besides the Honda gaskets are better. IMO
Old Jan 13, 2003 | 03:18 PM
redteg's Avatar
Default Re: ls headgasket (turbohonda)
thanks do u have any other tips on how to make it very reliable
golf-mk3
Feb 22, 2010 07:00 AM
URNVS
Jun 17, 2006 07:44 AM
f22suzuka
Aug 17, 2004 04:11 PM
L5turbo415
Feb 12, 2004 09:21 PM
Dancing is Forbidden
Mar 21, 2003 07:18 PM
