84mm and stock ecu
Old Jan 16, 2003 | 05:34 AM
baphomet's Avatar
Modified by b3435 at 9:27 PM 6/14/2003
Old Jan 16, 2003 | 08:11 AM
mos's Avatar
mos
Default Re: 84mm and stock ecu (b3435)
The SMC only cuts fuel, it doesnt allow you to add fuel. You could raise your fuel pressure, and use an SMC to dial your a/f in all over. That might work.
Old Jan 16, 2003 | 08:20 AM
Sonny's Avatar
You can just increase your fuel pressure via an adjustable FPR as a rough way to get things dialed in.
Sonny
Old Jan 16, 2003 | 09:10 AM
autoEXturbo's Avatar
if you running a fmu setup you'll be fine, just bumpt the fuel with the afc. After i had my block sleeved, put it all together, put the turbo and put it right on the dyno. I guess my break in period was driving it out of the shop and onto the dyno, not even a 1/4mile.
DelSolMarine
Apr 3, 2012 11:27 AM
keving85
Mar 22, 2009 08:55 PM
eg_gsr11
Aug 14, 2007 02:40 PM
Wicked_CRX
Jul 12, 2003 12:33 AM
01itr518
Jan 13, 2002 03:09 AM
