Car won't start!
Old Jan 15, 2003 | 03:08 PM
NX_LS's Avatar
Default Car won't start!
So about 3 days ago, I did a clutch install. Everything went good, until the moment of truth. I went to start the car, and it sounded absolutely horrible. It barely turned over, and when it did, I had to keep it at WOT just to get it to idle. The motor got flooded with fuel and eventually cut on me.
Now....it sounds alright when I try to turn it over, it just won't turn over.
I know it could be one of a million things. We've checked all vacume lines, all sensor's, and all ground wire connections....and everything is fine.
What is going on here?
Old Jan 15, 2003 | 08:28 PM
p0gi's Avatar
Default Re: Car won't start! (NX_LS)
This is probably stupid but did you check to see if the map sensor and tps sensor plugs were reversed? I dont know if you removed it while doing a clutch job but worth a look anyways It happened to me and took 4 months to figure out. Car did the same thing yours did.
d15bflat
Jul 7, 2009 12:29 PM
rampriderslocal
Jan 31, 2009 10:05 AM
i hate rice
19
Jun 25, 2006 12:49 PM
mericbe
Aug 20, 2005 09:52 AM
