Resleeving b16
Old Jan 12, 2003 | 09:10 PM
SiRkid's Avatar
Default Resleeving b16
Im looking at resleeving my motor with 84mm sleeves.
What kind of diplacement am I looking at? will it reach 1.8L or will it just be shy of it? and will this really screw up the r/s of the b16?
Im thinking of darton's and I have a local shop that is really good(knock on wood).
any other tips, hints and or info is welcome
Old Jan 12, 2003 | 09:28 PM
boosted hybrid's Avatar
Default Re: Resleeving b16 (SiRkid)
You should be at 1.7 liter i believe with 84mm sleeves. If you are looking into sleeving, golden eagle stuff is very nice. I have a 2.0 gsr block with golden eagle sleeves, and the quality is top notch. You cant beat the price as well compared to darton sleeves. As far as the r/s ratio is concerned, it should have minimal effect.
Old Jan 12, 2003 | 10:21 PM
mos's Avatar
mos
Default Re: Resleeving b16 (boosted hybrid)
Piston diameter does not effect r/s ratio.
You could try a piston with a raised piston pin location if you want a slightly better than stock r/s ratio, but you would also need custom long rods. Probably not worth it.
Old Jan 13, 2003 | 12:50 AM
see2k's Avatar
Default Re: Resleeving b16 (mos)
here i thought when he said r/s he meant resale value of the car..
so then what does R/S stand for
Old Jan 13, 2003 | 01:30 AM
turbohonda's Avatar
Default Re: Resleeving b16 (see2k)
rod to stroke ratio. It is determined by the stroke and the rod length.
Old Jan 13, 2003 | 01:46 PM
SiRkid's Avatar
Default Re: Resleeving b16 (turbohonda)
thanks guys!
*thinking*
Old Jan 13, 2003 | 02:03 PM
BudaKai's Avatar
If you have a first gen B16 your R/S is like 1.74:1. You can't get too much better than that.
Old Jan 13, 2003 | 02:27 PM
SiRkid's Avatar
Default Re: Resleeving b16 (tzsir)
how and why is the second gen diff?
****..reading all this ge vs darton stuff is crazy.there is a local shop that will do an awesome job (for dartons) and im sure of it but ge is good too...(well some of the probs lately worried me)..man...
also will i NEED new bearings? headbolts etc?
[Modified by SiRkid, 12:09 AM 1/14/2003]
Old Jan 13, 2003 | 08:34 PM
SiRkid's Avatar
ttt
Old Jan 13, 2003 | 10:54 PM
MotorMatrix.com's Avatar
I am a bad person
the set of 84mm pistons i just got from je list the displacement as 1.71. you could order them to be used with an ls crank and then you will get close to a 2.0 liter.
master honda tech
Aug 24, 2005 09:32 AM
xDicktonesx
May 17, 2005 01:53 PM
gumbybum
Dec 20, 2003 08:45 PM
Ehron
May 28, 2002 10:04 AM
paulzy
Jan 22, 2002 07:27 PM
