Golden Eagle Mfg. Fuel Rail!
Here we go again. We have Fuel rails hitting the market by the end of the week. these rails are top quality and come in three different colors:
Black
Titanium
Silver
Each fuel rail is satin finish and anodized then engraved for long lasting good look. These rails utilize o-ring fittings that ensure no leaks. You can buy either the AN adapter fittings or the stock "Banjo" fittings from us too. They have location for the stock regulator if needed and a port that can be used for a gauge or a pressure sending unit. These rails have the highest flow of ANY other fuel rails on the market. PLus since you can purchase them factory direct, you get a big savings on anything you buy from us.
Front of a B-series Black rail.
Showing the O-ring port in the rail!
Black and Titanium!! We also have silver.
The underside of the rails!
We have many applications :
Acura/Honda B-series, H-series, D-series, GM Ecotec, Ford Duratec, Skyline, Focus, and many more coming soon.
www.goldeneaglemfg.com (909) 592 - 4311 sales@goldeneaglemfg.com
[Modified by GoldenEagleMfg.com, 6:20 AM 1/14/2003]
Black
Titanium
Silver
Re: Golden Eagle Mfg. Fuel Rail! (GoldenEagleMfg.com)
Oh my God, you guys are trying to take all of my money aren't you. Damn, nice new products. You will be getting a call from me soon!
Re: Golden Eagle Mfg. Fuel Rail! (MyWhiteCivic)
[Modified by B18Flip, 1:31 AM 1/14/2003]
Re: Golden Eagle Mfg. Fuel Rail! (B18Flip)
You just made me shopping soooooooo much easier! All I need now is a very good high volume intake manifold for a D series and i'm set!
Re: Golden Eagle Mfg. Fuel Rail! (boostedcvc)
damn you guys got all kinds of cool **** kicking.
I really dig your cam gears too.
Hope you plan on adding the f-series parts to your lineup.
So wait.... The hardware isn't "included" in the kit? From what I read, hardware is sold separately. How big are the feed holes? I'm guessing -8AN. Skyline application.... are you implying GTR application, or just regular RB25 motor....and if you are implying GTR application, which fuel pressure regulator will you be using and where will your fuel feed be located?
Re: Golden Eagle Mfg. Fuel Rail! (earl)
These rails have the highest flow of ANY other fuel rails on the market. Please tell me what test you did against what other manufactured fuel rails to make this claim. We all want better flow so how does your new improved rail do this?
Re: Golden Eagle Mfg. Fuel Rail! (Jason kiDD)
Agreed want more information on this. And also you know you need to make one adonized in red. Just for me!! I swear the red ones will be your best seller. Think about it..
Re: Golden Eagle Mfg. Fuel Rail! (VTC_boost-less_CiViC)
We will have all the D-series stuff together very shortly. We have all the OG Intake manifolds for B, D, and H-series as well as some others as well as a cast turbo masnifold for all B-series. This is coming very very soon!!!!
We have the largest fuel flow hole on the market. It is an 11/16 ( .6875 ) hole in the rail which means that there is no injector flutter because of the large " plenum " in which the injectors have to pull from. We can supply you with either a -8 or -10 AN fitting which we make as well as the stock adapter if you need it.
Re: Golden Eagle Mfg. Fuel Rail! (twkdCD595)
We will have all the F-series stuff as well. E-mail me from time to time and I will let you know when they are available!
Are you doing any actual turbo "kits" in the future? Also what style of intake manifolds are you releasing? Can I get any pics, or flow rates they are tested for?
Now you need to make a FPR to go along with it. How about WG's and BOV's too.
I personally think someone should make an aftermarket extruded head like Payn had Dart make for engine blocks. JMO
We will have all the D-series stuff together very shortly. We have all the OG Intake manifolds for B, D, and H-series as well as some others as well as a cast turbo manifold for all B-series. This is coming very very soon!!!
Re: Golden Eagle Mfg. Fuel Rail! (importbeat)
Re: Golden Eagle Mfg. Fuel Rail! (teampr1ckcivic)
Yes, the kit comes with the stock adapter to the banjo fitting and also has the plug for the other end. It also has an option for a -6, -8 or -10AN fitting!!!
