tuning with no exhaust?
Old Jan 13, 2003 | 04:14 PM
aesthetics82's Avatar
Default tuning with no exhaust?
i currently am running a drag III turbo kit on my b16 with hondata 2b. i have the stock exhaust on still but want to upgrade it for more power but i dont wanna spend the money on it....here's what my idea is..i wanna take off the stock exhaust and run only the downpipe at the track and get it tuned at a shop like this. then when im back on the street i'll re-attach the stock exhaust. if i get the car tuned with no exhaust will it run a lot more rich when the stock exhaust is put back on? would it be driveable if the tuning was meant for no exhaust but i drove around with an exhaust? and the second question is...if i only have the first o2 sensor plugged in and not the one that goes into the cat, will i get a cel (check engine light), the car is obd1. and one last question, can somone explain how i can get the car tuned to run 8psi on the street and 10 psi at the track. can this be done with hondata and not having to switch between chips..if someone could go into the tuning process in depth i would really appreciate it.thanks for all the help guys.
Old Jan 14, 2003 | 08:01 AM
Default Re: tuning with no exhaust? (aesthetics82)
i know there is someone out there that can help me out.
Old Jan 14, 2003 | 08:23 PM
anyone? please help
Old Jan 14, 2003 | 08:33 PM
vtec.dc2's Avatar
just tune it with a different chip, then switch them, one for exhaust which you already have.. and one for no exhaust - for the track
i think theres a way to burn more than one program on same chip, but you'd need more than 2b to be able to switch
[Modified by vtec.dc2, 1:19 AM 1/15/2003]
Old Jan 14, 2003 | 09:08 PM
black92si's Avatar
my OBD1 car has but only ONE o2 sensor
Old Jan 14, 2003 | 10:32 PM
Default Re: tuning with no exhaust? (vtec.dc2)
does anyone know if i can burn different chips with hondata 2b?.....or if i would definately have to switch between two chips, one with exhaust and one without? thanks.
Old Jan 16, 2003 | 10:22 AM
i thought i would get more than 2 responses...there seems to be a lot of knowledgeable people here...can someone help me out?
Old Jan 16, 2003 | 10:28 AM
vtec.dc2's Avatar
as i mentioned before, you can have more than one program on the same chip, but you can not switch between these unless you have the complete dealer stage 4b or s200 with whatever needed. my suggestion is to tune your car for no exhaust, and switch between 2 chips.
rsangha13
Mar 18, 2013 08:28 AM
Scotty Dosent Know
Aug 31, 2007 01:24 PM
debogsr
Aug 12, 2005 02:46 PM
5thgencivic
Dec 23, 2003 12:12 PM
Mr.DC2TurBo
Oct 27, 2003 02:51 AM
