My turbo project (pics)!!!!!!!
Old Jan 13, 2003 | 12:26 PM
QCKGSR's Avatar
Default My turbo project (pics)!!!!!!!
Just some pics that I took while fitting together some pieces to the puzzle....
Gimme some replies, Thanks
[Modified by QCKGSR, 9:34 PM 1/13/2003]
Old Jan 13, 2003 | 12:34 PM
Evil DOHC's Avatar
Default Re: My turbo project (pics)!!!!!!! (QCKGSR)
What size snail/
EVIL
Old Jan 13, 2003 | 12:42 PM
QCKGSR's Avatar
Default Re: My turbo project (Evil GS-R)
It is a sc63 from precision turbo...It has a P-trim exhaust turbine and a 63mm compressor wheel...it is a bad *** custom turbo, it cost me alot of time and money
Old Jan 13, 2003 | 01:00 PM
HXMan's Avatar
Nice!
Old Jan 13, 2003 | 01:07 PM
paulzy's Avatar
Default Re: My turbo project (HXMan)
nice...what brand is that fuel pump? I've never seen that label on that fuel pump b4
Old Jan 13, 2003 | 01:14 PM
shortyz's Avatar
Default Re: My turbo project (1320development)
yeah what brand fuel pump and whats it rated at?
Old Jan 13, 2003 | 01:25 PM
PeakBoost's Avatar
B*A*N*N*E*D
Default Re: My turbo project (shortyz)
its an aeromotive with the cartech name on it. here is a link for more info: http://www.cartech.net/fuelsystems.htm scroll halfway down the page.
Old Jan 13, 2003 | 01:27 PM
SiRkid's Avatar
Default Re: My turbo project (CHEAPTURBOdotCOM)
nice set up
Old Jan 13, 2003 | 01:37 PM
BoostedH23a1's Avatar
Default Re: My turbo project (SiRkid)
what the hell is that blue thing? water pump or something
Old Jan 13, 2003 | 01:47 PM
wickedxboi's Avatar
looks like a electric water pump
what kind of manifold is that?
spf?
Old Jan 13, 2003 | 02:00 PM
BudaKai's Avatar
Default Re: My turbo project (wickedxboi)
Maziere water pump? Is that the aluminized powder coated manifold?
Very nice....
Old Jan 13, 2003 | 11:03 PM
JUNcr-x's Avatar
Default Re: My turbo project (tzsir)
very nice setup looks fun!!!
Old Jan 13, 2003 | 11:42 PM
Goldfingiz's Avatar
Looks good Your valve cover kinda changed color towards the end there ;]
Goldfingiz
Old Jan 14, 2003 | 05:41 AM
QCKGSR's Avatar
The pump is cartech with a 1000hp rating.... the motor is a spare race motor from the signal race team, they never campaigned this year so they had an extra motor they needed to sell, its a B16B , with a civic type r cylinder head the head is fully done with ceramic coating inside the exhaust and intake ports... it has a type r crank with crower rods and ross pistons 82mm , ferrea vavletrain the faces have been ceramic coated, civic type r cams, electric water pump, head and main studs the fuel system is cartech pump -10 lines to holley fuel rail(prototype) to 980cc inj.. and -4 return.. im gonna run a open down pipe and hope to make in the 600 range to the wheels... 625???
Old Jan 14, 2003 | 06:42 AM
bambooluv's Avatar
Default Re: My turbo project (QCKGSR)
what kind of turbo manifold is that and what year integra is your car?
is it a rev-hard equal length manifold for 91-93 integra?
Old Jan 14, 2003 | 06:51 AM
swrdply400mrelay's Avatar
Where'd you get that water pump?
Old Jan 14, 2003 | 09:28 AM
MotorMatrix.com's Avatar
I am a bad person
Default Re: My turbo project (swrdply400mrelay)
Nice setup. do it right the first time!!!
Old Jan 14, 2003 | 09:39 AM
Speedworks801's Avatar
Default Re: My turbo project (MotorMatrix.com)
Sounds like somebody did their homework!
Keep us posted! . . . literally.
Old Jan 14, 2003 | 10:00 AM
silverEH2's Avatar
Default Re: My turbo project (Speedworks801)
i like your manifold
Old Jan 14, 2003 | 11:31 AM
newspeedR's Avatar
How do you plan on hooking the fuel pump up.. sump, cell?
Old Jan 14, 2003 | 02:09 PM
QCKGSR's Avatar
Default Re: My turbo project (newspeedR)
Thanks for all the nice replies,
i plan to pull the fuel from the stock sump just modified a bit, with a 5/8 fuel line welded up to a bulkhead -10.. -10 line up to the fuel rail....
Old Jan 14, 2003 | 08:39 PM
Sinisterh22a's Avatar
hey steve its adam with the accord the one that got the cam from you anyway just wondering why you boosting now? you had a sick all motor set up, what happend to the all motor motor? wanna get rid of anything and also how the hell do you find out if signal has a spare motor?
Old Jan 14, 2003 | 08:53 PM
TurbothisLS's Avatar
Default Re: My turbo project (Sinisterh22a)
looks like you picked out some highend stuff
good luck man
Old Jan 14, 2003 | 08:57 PM
D16A6Turbo's Avatar
are you basically gonna run it like an in-line pump that works in conjunction w/ the stock in-tank? Are you gonna mount the cartech under the hood?
[Modified by D16A6Turbo, 5:58 AM 1/15/2003]
Old Jan 14, 2003 | 10:20 PM
I am a bad person
Default Re: My turbo project (D16A6Turbo)
doubt he will run the in tank as it will be limiting the big pump sucking thru the small in tank.
