Loctite for LSD install?
Old Jan 15, 2003 | 01:52 PM
niedejb's Avatar
Default Loctite for LSD install?
Should I use loctite on the bolts that hold the final drive gear to the differential?
Service manual says nothing about loctite, but tag on the quaife says "Warning Bolts Secured With Loctite".
Had bad experiences with loctite. Just wondering what you guys have done.
Old Jan 15, 2003 | 01:54 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: Loctite for LSD install? (niedejb)
i used loctite... no problems here
Old Jan 15, 2003 | 02:27 PM
turbohonda's Avatar
Default Re: Loctite for LSD install? (Boosted97Lude)
You don't need loctite on the bolts that hold the ring gear to the diff. The B-series bolts are left hand threads and you torque them to 74ft lbs. The tag on the Quaife is saying that the allen bolts that hold the diff together have loctite on them already.
Old Jan 16, 2003 | 02:32 AM
niedejb's Avatar
Default Re: Loctite for LSD install? (turbohonda)
Thanks
JBLAZE622
Transmission & Drivetrain
Apr 15, 2010 11:00 PM
mhewitt
Dec 10, 2008 08:03 AM
White_EK49
Oct 10, 2005 07:08 AM
