Help on T3/TO4b
Old Jan 12, 2003 | 11:08 PM
Trac226's Avatar
Default Help on T3/TO4b
This is off a DRAG kit and I was wondering if it will support my goal of 300-350 whp on a gsr, or will this be pushing it's effeciency limits?
edit: to help narrow down variables, let's say it's hondata tuned, 440 injectors, 3" exhaust.
[Modified by Trac226, 8:10 AM 1/13/2003]
Old Jan 12, 2003 | 11:12 PM
Flamenco-T's Avatar
Default Re: Help on T3/TO4b (Trac226)
hmm, you may have to run high boost to get that...at that point. 10 psi will prolly get you about 220ish HP..., so you're looking at 16-18psi to achieve your goal....
just run T3/4E. make life simpler, less boost, same HP
stan
Old Jan 12, 2003 | 11:14 PM
Flamenco-T's Avatar
Default Re: Help on T3/TO4b (Flamenco-T)
on my old setup, I made around 270ish at 8psi with T04E housing on a stock GS-R motor with 2.25" exhaust.
with 04E housing, hondata, 440cc and 3" exhaust, you should be able to hit 300 with 12psi ish....maybe less...compare to 16-18psi on 04B housing
stan
Old Jan 12, 2003 | 11:20 PM
Trac226's Avatar
Thanks, that's what I was figuring as well...I think the t3/to4e 57 trim 63 a/r might suit me better.
[Modified by Trac226, 8:20 AM 1/13/2003]
Old Jan 12, 2003 | 11:32 PM
Flamenco-T's Avatar
yeah, you'll be happy with 57 trim, I had the 54 trim and 57 always beat me my *** all the time hehehe
that's why I use precision 60-1 now heheh
FYI, check with arturbo for pricing of t3/4e turbo...he get good deals on precision turbo ...better than turbonetics..
stan
Old Jan 13, 2003 | 12:18 AM
ninesecrx's Avatar
Stan, just so U know, I ran a t3/t4 with a 54 trim with a stage 3 exhaust on my race car a couple years back and made 450hp at like 17 pounds of boost.
Old Jan 13, 2003 | 02:37 PM
Trac226's Avatar
Default Re: Help on T3/TO4b (ninesecrx)
How's that 60-1 working out for you stan?
spoolin turbo s
Oct 19, 2008 05:18 PM
92HB_HB
May 9, 2003 09:35 AM
ls-t del sol
Jan 17, 2003 12:47 PM
Stock@$$GSR
May 24, 2002 02:54 PM
DLB1994
Mar 13, 2002 06:27 PM
