Inside a 60-1
Old Jan 14, 2003 | 11:23 PM
boostaholic's Avatar
Default Inside a 60-1
Got bored tonite so i decided to open up my 60-1 and clean it up a little. Took lots of pics for you guys while i was measuring the wheels.
Specs:
Innovative Turbo Systems t3/60-1
60-1 wheel
T04s compressor housing
.70 a/r comp.
Stage 5 exh. wheel
.63 a/r exhaust housing
60-1 wheel
Inducer - 2.324"
Exducer - 3.000"
Stage 5 exhaust wheel
Exducer - 2.439"
Major - 2.798"
Center section, don't mind the black stuff on the exhaust side. It's just exhaust gas baked on it, the turbo has about 8k miles on it so far.
Compressor housing 4" inlet
Exhaust housing 2.450" outlet
Turbo back in the car
Happy boosting!
Old Jan 14, 2003 | 11:48 PM
B18EG6's Avatar
Default Re: Inside a 60-1 (boostaholic)
hehe looks like you have a lot of time on your hands!
AWESOME pictures!
Old Jan 15, 2003 | 12:14 AM
LJR-LUDE01's Avatar
Default Re: Inside a 60-1 (B18EG6)
good picstures... now I know exactly what my t3/t60-1 is suppose to look like
Old Jan 15, 2003 | 12:24 AM
Flamenco-T's Avatar
Default Re: Inside a 60-1 (LJR-LUDE01)
here's my 60-1 HiFi, the Precision SC60
Stage 3 .63 wheel
2.324" inducer, 3" Exducer, T04E housing 3" Inlet ( HiFi version) and Stage 3.63 AR Turbine housing.
stan
Old Jan 15, 2003 | 06:49 AM
BudaKai's Avatar
That precision piece looks to be of a higher caliber (as in quality).
Very nice indeed T.
Old Jan 15, 2003 | 06:54 AM
Evil DOHC's Avatar
Default Re: Inside a 60-1 (tzsir)
Damn, what size is that feedline? WOW
EVIL
Old Jan 15, 2003 | 07:03 AM
boostin b16's Avatar
Default Re: Inside a 60-1 (Evil GS-R)
how do you like that t3/60-1? what rpm does it spool at? and does it thrive over 12 psi? i just bought one and i am worried i may have made a wrong choice. how do you think it compares to a t4/60-1? if you had to do it again would you choose the same turbo? what are the pros and cons? is the turbo pleasing to the eye?(does it look big?)
thaNX in advance
Old Jan 15, 2003 | 08:06 AM
onetwothree's Avatar
Default Re: Inside a 60-1 (boostin b16)
I'm with boostinb16 on this one. so whats the deal?
Old Jan 15, 2003 | 08:34 AM
TurbothisLS's Avatar
nice pics
Old Jan 15, 2003 | 09:09 AM
Speedworks801's Avatar
Default Re: Inside a 60-1 (TurbothisLS)
That's the same one I got! Love it. 6psi by 4500, 14psi by 5200. Punches my Kuhmo V700's loose in third sometimes when it hits. Michelins are useless. LOVE THAT TURBO!!!
Old Jan 15, 2003 | 10:00 AM
Mr. Vapor's Avatar
Default Re: Inside a 60-1 (Speedworks801)
did you notice any increase in spool time etc after the cleaning?
Old Jan 15, 2003 | 10:39 AM
legendboy's Avatar
Default Re: Inside a 60-1 (NYb16)
So the "trim" of the 60-1 compressor is .60? What makes that different than a .60 TO4? Same thing?
[Modified by legendboy, 12:49 PM 1/15/2003]
Old Jan 15, 2003 | 11:55 AM
Flamenco-T's Avatar
Default Re: Inside a 60-1 (legendboy)
A regular 60 trim on the T04E is housing is liek any regular 04E wheel, 6 blades, 60mm inducer and 2.95" exducer.
The 60-1 wheel are 7 blades, 59mm inducer and 3" exducer.
the 60-1 HiFi is on a regular T04E housing 3" Inlet and 2" outlet on a t3 cartridge, the standard 60-1 is on the T04S housing .70AR with 4" inlet and 2.5" Outlet on the t04 cartridge.
the HiFi series flows about 80-90% in comparison with the standard 60-1. The turbine wheel can be either one depending on the housing...stage 5 or stage 3.
stan
Old Jan 15, 2003 | 01:27 PM
Default Re: Inside a 60-1 (Flamenco-T)
At full load and WOT, the turbo makes 1psi at about 3500rpm and 12psi at 4900rpm. This is on a stock LS block and head.
Old Jan 15, 2003 | 02:29 PM
LS-hatch's Avatar
What size DP and exh. are you running? Those rpm numbers are making me consider getting a 60-1 on my LS.
Old Jan 15, 2003 | 03:11 PM
legendboy's Avatar
Ok, good info. I have another question. I just measured my exducer. I have an older Aireasearch T04 with a 4" inlet. The minor is 2.17" and the major is 2.75 The wheel has 8 double blades. Using this my trim is:
[(2.17)^2 / (2.75)^2] X 100 = 62 trim??? What the hell is that? I measured the minor at 55mm exactly so this is right.
what turbo do I have? Here is a picture: (t3/t4 w/ .48 turbine)
[Modified by legendboy, 5:16 PM 1/15/2003]
Old Jan 15, 2003 | 03:28 PM
done's Avatar
That Precision turbo looks excellent...
Innoative also *yummm...
my sc44, its tiny compared to your turbos..
Old Jan 15, 2003 | 03:38 PM
PeakBoost's Avatar
B*A*N*N*E*D
well the 2.18 inducer 2.76 exducer are the specs for the to4b 63 trim wheel..
Old Jan 15, 2003 | 04:06 PM
DIRep972's Avatar
Smarter than you
Default Re: Inside a 60-1 (CHEAPTURBOdotCOM)
i guess this would be the right thread to ask this in.
im looking at my turbonetics catalog right now. im specifically looking at the specs on the T04e's vs. the t04b's.
to4b v-trim has a flow rate of 51lb/min
to4b H-trim flows 53lb/min
t04e 57trim flows 49lbs/min
t04e 60trim flows 50lbs/min
and for fun it says the t04b(is that really an S) 60-1 flows 57lb/min
now how come every turbo car ive seen running a t04e 57 trim makes like 30 more hp then a t04b vtrim. the vtrim has a higher flow rate??????? are these #'s in the catalog correct?
Old Jan 15, 2003 | 04:53 PM
Default Re: Inside a 60-1 (LS-hatch)
3" downpipe, 3" exhaust.
Old Jan 15, 2003 | 07:36 PM
speed's Avatar
Default Re: Inside a 60-1 (DIRep427)
_______
I'd also like to know this...
Old Jan 15, 2003 | 08:25 PM
SiRkid's Avatar
i should take some pics of my turbo..
i had it apart like that about a month ago.
alperx
Feb 8, 2012 05:34 PM
jarvis199
May 15, 2007 11:55 AM
GraphiteAccord
Oct 21, 2003 02:08 PM
specie
Jan 15, 2003 06:15 PM
PrecisionH23a
Oct 5, 2002 12:26 PM
