Lookin to build a 1500 $ turbo kit for b18a.
Guest
Posts: n/a
is this possible, and if so, what parts would you guys reccomend, im down for getting a custom manifold from someone here on the board, im open to all suggestions, and yes i would like it to be intercooled with injectors and such. i currently have a SAFC and ignition, so those things are already done. But i was thinking for the kit, some type of manifold with a T3/TO4E turbo (need suggestions on where to get a good but cheap one), and id have a custom downpipe and exaust made, all pipes would be pretty much custom, greddy type S BOV, DSM injectors, and ect ect. just need what u guys think would be a good buildup for around that pricerange.
Guest
Posts: n/a
Re: Lookin to build a 1500 $ turbo kit for b18a. (HybridcivicLS-T)
ya, its like ALL the work will be done cept for the piping by me and my freinds. we know what we are doing so no worries there. member boostinb18 swears up and down he can build a nice reliable turbo kit for like 1500-2000$
Re: Lookin to build a 1500 $ turbo kit for b18a. (-Racer X-)
im trying the same right now. The only things that I am really having trouble finding cheap is the turbo itself. Other than that its easy. for the IC go with either a starion or half of a ford powerstroke IC. The ford one can be cut in half with new endtanks welded on each. The best part is that the other one will sell for probably as much as you paid for the whole IC. Hopefully you know someone who can weld for you becasue paying someone to do it will cost a lot more than paying a friend (especially since some friends accept beer as payment ). Of course do DSM 450cc injectors. Get your piping for JC whitney. As for the mani, keep watching places like ebay and used parts places. Good luck.
Guest
Posts: n/a
Re: Lookin to build a 1500 $ turbo kit for b18a. (LS-hatch)
ya, i heard the starion one is good, but i sorta want a big intercooler showin up front im not sure tho, if there are really no preformance diffs then i will go with the starion, and i think my freind said to go to cheapturbos.com for a cheap T3/TO4E.
sure you could build a turbo for that much, but then will it be reliable?
Either spend the money now, or spend alot more later, its up to you
Guest
Posts: n/a
Re: Lookin to build a 1500 $ turbo kit for b18a. (Canuk_SiR)
t3/t4 $550
manifold $450
dsm injectors $100
smc+ $150
bends/hoses $100
dp $150
You can do it, but you will probably end up buying a bunch of other things too. Like gauges and sensors, those are nice to have, so you can tell wtf is happening. Some people on here have done it for less, but they did a lot of work themselves.
manifold $450
dsm injectors $100
smc+ $150
bends/hoses $100
dp $150
I've got right at $400 spent on mine, and it looks it. Aside from an initial problem with an unbraced downpipe smacking against road debris and stressing the turbo flange until it broke, I've been totally reliable turbo-wise for 10K now. I run very low boost (4 psi) daily, more to keep the stress off the engine than because it can't handle more.
The only moving parts (read: wear out quickly) in the turbo setup are the turbo/wastegate assembly and the BOV. At $100-150 for a T3 w/ some shopping around and $30 for a Bosch standard BOV, it's not too bad. PVC makes for some groovy charge pipe.
Guest
Posts: n/a
Re: Lookin to build a 1500 $ turbo kit for b18a. (mos)
ya im down for the crown when it comes to work, and i can get greedy stuff for cheap since im a dealer...lol so a boost guage and turbo timer wouldent be a problem, and its also a good thing i already have a safc. hack time baby!
my whole custom kit for a b16 is under 1500. check my sig for my internet site with pics of my project. 1500 is a good number. u can do a great kit for that money.
Re: Lookin to build a 1500 $ turbo kit for b18a. (J. Davis)
Well, that would fill up the front grill aesthetically, but the problem with the PS IC is that it flows like a cow turd. I'd go elsewhere... they are boost drop city. Joining two Dodge 2.2 or two Mitsu SMIC's together has definite merit for the homebrew turbo.
for 400 $ cant you just buy a good intercooler?
Ported/Clipped/Rebuilt 14b turbo-- 100$
Spearco off E Bay-- 225$
Custom Manifold-- 300$
FMU-- 100$
BOV-- 1G DSM 30$
Fuel Pump-90$
Piping from your boys--- Priceless
FMU-- 100$
BOV-- 1G DSM 30$
Fuel Pump-90$
Guest
Posts: n/a
Re: Lookin to build a 1500 $ turbo kit for b18a. (Drag_On)
FMU-- 100$
BOV-- 1G DSM 30$
Fuel Pump-90$
FMU-- 100$
BOV-- 1G DSM 30$
Fuel Pump-90$
Re: Lookin to build a 1500 $ turbo kit for b18a. (2b_FaSt)
Ware do people get the crazy turbo manifolds?
Thanks,
Thanks,
