spark plugs
Old Feb 6, 2003 | 02:25 PM
ludelvr's Avatar
Default spark plugs
Just wondering on a 95 civic d16z, if the stock spark plugs are a 5 rating, should I jump up to a 6 or a 7? And if it is a 6, could I use the stock plugs off of a 94 lude vtec since it's a 6 rating, and what gaps for each of these? I've been told that I could use the stock d16z 5 ratings with a stock gap and it should be fine. Any thoughts or suggestions?
Old Feb 6, 2003 | 03:26 PM
93 VTEC's Avatar
Default Re: spark plugs (ludelvr)
I wouldn't use the stock Prelude VTEC plugs because they are platinum. What do you plan to do with the car? If you are planning any sort of FI then I would go to your local dealer and ask for P/N 98079-5714G (NGK ZFR-7F11). They are two steps colder than your stock plugs and they are copper.
Old Feb 6, 2003 | 10:29 PM
ludelvr's Avatar
Default Re: spark plugs (93 VTEC)
The d16z is gonna be forced fed. Jeff from homemadeturbo.com said he's run many FI'd setups with stock plugs at with a stock gap and they've run fine. I was just curious as to opinions on this. I'll see how each one runs but I'd just like a bit more input. thanks
skinney6
Aug 26, 2012 12:13 PM
skierGT
Jun 17, 2003 05:06 AM
GRAVEDIGGER
Jun 18, 2002 01:48 PM
maggsgsr
Apr 4, 2002 08:18 AM
Babalouie
Jun 24, 2001 07:33 PM
