Question for AEM guys
Old Feb 6, 2003 | 08:02 AM
underpressure02's Avatar
Default Question for AEM guys
Yesterday it came up in a thread about the popping or missing while the car is idling. I had the same problem with my old motor before it blew. Now my new stock motor is doing the same thing. Does anyone know what is causing this or is this normal for the AEM unit? I put new plug in and they all seem to be fine. It sounds more like a popping then a misfire.
Old Feb 6, 2003 | 03:38 PM
Default Re: Question for AEM guys (underpressure (wtbimport))
anyone?
Old Feb 12, 2003 | 06:36 AM
ttt
Old Feb 12, 2003 | 06:42 AM
Mase's Avatar
try to richen up the idle slightly.....lol i had my idle down perfect, but being gay i messed around w/ crap more, and now it lopes a little..heh..... but when i had it perfect, it idled around 13.7~13.9 afr. i remember reading a couple guys had problems w/ it popping around stoich
Old Feb 12, 2003 | 01:23 PM
Default Re: Question for AEM guys (Mase)
I do not have a wide ban but I do not think it needs to be richened. It leaves puddles of black sout on my garage floor. So that poping noise is not something to worry about?
Old Feb 12, 2003 | 01:26 PM
falcongsr's Avatar
What is this crap?
popping in the exhaust is misfiring. something is wrong. my car doesnt pop.
maybe its hella rich. user echo had problems like this i dont know what the resolution was.
Old Feb 12, 2003 | 01:43 PM
echo999's Avatar
New User
Default Re: Question for AEM guys (falconGSR)
Don't have a resolution... I've been on a crazy chase:
0) Replaced plugs/wires.
1) Replaced distributor cap, rotor, ignitor
2) Fixed the missing exhaust manifold bolt.. checked whole engine for vacuum leaks
3) Tried everything on EMS forum that was recommended.
4) Checked compression, thinking it could be bad rings/valves
5) Thinking it's fuel pump now, or FPR...
FalconGSR just told me to try the 310 map instead of the 440.. Gonna give it a
shot this weekend, and let you know. Could be that the UI doesn't let us tweak
some other variables.. who knows.
Old Feb 12, 2003 | 02:06 PM
falcongsr's Avatar
What is this crap?
Default Re: Question for AEM guys (echo999)
i've had multiple successes resolving all kinds of idling issues with the Turbo 310 base map. drop in your fuel map, timing map, map max and min, recal the TPS, drop in your AFR #1 map if u have a wideband o2 controller, and turn the key.
Old Feb 12, 2003 | 02:10 PM
Hey echo I think you responded to my post on the AEM board. Let me know if you come up with anything. Thank you also falcon
Old Feb 27, 2003 | 11:43 PM
98Psi ITR's Avatar
Default Re: Question for AEM guys (underpressure02)
How do you expect to do any tuning without a wideband sensor. There was about a 5 point difference in AF when I did my car between the stock O2 and a wideband.
Old Feb 28, 2003 | 04:48 AM
MiraiZ's Avatar
Default Re: Question for AEM guys (98Psi ITR)
My guess (and this is by personal experience -may not apply in your case)...oil maybe getting into one of your cylinders due to a blown headgasket or blown rings...do a compression check, and also see if you can do a visual check through the sparkpulg holes. see if the top of the pistons look oily or wet.
[Modified by MiraiZ, 10:49 PM 2/28/2003]
Old Feb 28, 2003 | 05:32 AM
Tinker219's Avatar
If I remember correctly, I remember hearing about this somewhere....the determined culprit(i think) was over-rich conditions...
Old Feb 28, 2003 | 05:50 AM
falcongsr's Avatar
What is this crap?
Default Re: Question for AEM guys (Tinker219)
update: i think echo is looking at coil / igniter cause he's getting intermittent spark
Old Feb 28, 2003 | 06:14 AM
echo999's Avatar
New User
UPDATE on my situation:
I connected my timing light to the wires, and found that #1 and #4 were missing
intermittently. After a series of misses, I would hear a thump in the exhaust.
I'm thinking that the thump is caused by unburned fuel (from the misses) igniting
in the exhaust.
I'm thinking of replacing my distributor at this point.
Old Feb 28, 2003 | 08:11 AM
Tinker219's Avatar
hopefully everything works out for ya...
oh ya, dont get jolted while hooking the timing light to the wires...that SUCKS
I was sore for a week...somehow my dist. still works though
Old Feb 28, 2003 | 08:32 AM
Muad'Dib's Avatar
Corr Performance Pilot
my exhasut does the same thing. I knew that it was more fuel than regularly but when I got on the dyno there was a misfire on the dyno chart. we pointed it down to the spark plugs and the wires which are stock from 98. I'll be changing the wires out and I should be burning the fuel better thus possibly eliminating the popping.
thanh1226
May 29, 2016 02:15 PM
dunkd
Dec 31, 2006 05:12 PM
Boostage
Jun 12, 2006 08:18 PM
E Swift
Feb 11, 2004 05:33 PM
1337 Si
Nov 19, 2003 02:16 PM
