changing boost setting and tuning
Old Feb 6, 2003 | 05:57 PM
514_type R's Avatar
Default changing boost setting and tuning
Ive always wondered how can you guys with turbo setup change the boost setup if your car is tuned with aem ems, hondata etc... For example if you tune your car at wide open throttle for 20psi of boost and then you switch to 10psi for daily driving, isnt the car going to run the setup you setted for 10psi, meaning ultra rich?
Or the hondata, aem,haltech etc.. simply adjust the fuel, timing level with your tuned a/f adjustement and re-ajust it when you run 10psi...meaning your car will always be fully tuned even at 10psi
thanks
Old Feb 6, 2003 | 06:04 PM
Tofurky's Avatar
Default Re: changing boost setting and tuning (514_type R)
if you have your car tuned for 20 psi... you are fine from 1-20 psi
Old Feb 6, 2003 | 07:53 PM
racerxadam's Avatar
read my reply here. https://honda-tech.com/zerothread?id=394241
Old Feb 6, 2003 | 08:28 PM
514_type R's Avatar
Default Re: changing boost setting and tuning (racerxadam)
thanks,
that means that if I tune the car for 18psi, it will be at the ideal setting also at 10psi, that way you dont always have to go back to dyno.
if you tune under WOT, is the hondata system is going to adjust also under medium throttle, or low?
Old Feb 6, 2003 | 08:36 PM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
The way I understand it you can tune the car for part throttle as well. A good tuner will make sure your car is running perfectly before you leave the facilities.
Old Feb 7, 2003 | 03:08 AM
racerxadam's Avatar
every position on the fuel and timing maps represents an rpm and a pressure or load value. for every rpm value on the map there are corresponding pressure values across the whole map. In order to run a lower pressure and have a good tune you need to tune for that part of the map, and then add pressure and tune for that part of the map and so forth. The logical thing to do IMO is to start with a conservative map and tune low boost first and then start adding boost and tuning the new parts of the map that are being used. Then when you turn the boost down you just don't end up using the high boost parts of the map
5thgencivic
Sep 17, 2003 06:41 PM
minivan81
Jun 13, 2003 08:10 AM
krazy
Mar 29, 2003 05:28 PM
BoostedD15B7
Mar 2, 2003 02:29 PM
