What bearings is everyone using for their high Hp Boost motors??
I am a bad person
I was just curious what bearing everyone is running on their boost motors. We have used clevite and had great luck with them so far but i keep hearing about the ACL bearings. this is one of those things that if you have had good luck with something why switch, but i was just curious. what about honda bearings??
Re: What bearings is everyone using for their high Hp Boost motors?? (MotorMatrix.com)
i dont make any power really..but acl's are in mine
im sure earl runs the acl's too
Re: What bearings is everyone using for their high Hp Boost motors?? (rOby)
im not making that much either but i use acl's and they plastiguaged perfectly, and they are real cheap
i like honda bearings. some hardcore v8 guys actually spin their cranks down to honda size, so they can run the honda bearing.
Re: What bearings is everyone using for their high Hp Boost motors?? (SEFI8LOxCivic)
I use the ACL bearings as well. It's true if your having luck with one company why switch unless proven otherwise.
Re: What bearings is everyone using for their high Hp Boost motors?? (vtecdoc)
if you're honda color is green, yellow or brown, you can have a pretty good luck with ACL, since I think they made ACl to work within the middle color of the OEM bearing chart..
but honda OEM are kick *** as well....tony uses honda oem
I used ACL....
I used ACL....
New User
I have waited so long as 3 months to put together a motor with OEM bearings. Thats how strong my faith is in them.
Re: What bearings is everyone using for their high Hp Boost motors?? (VaporTrail)
I will ONLY build a motor with honda bearings. Not that all others are bad, but they're not honda quality...
There has to be a reason why most Nascar motors have Honda bearings in them.
The surface (when magnified) has adjoined pyramids in which oil molecules ride in between and act as a ball bearing-type surface.
That was Mark (b20c5) in this thread:
http://theoldone.com/forum/topic.asp?TOPIC_ID=11608
This was about the structure of the bearing's surface.
Ive read that Nascar uses Honda's bearings somewhere.. if I can find it I'll post it.
[Modified by Dublocivic, 12:43 PM 2/5/2003]
Re: What bearings is everyone using for their high Hp Boost motors?? (AVATAR)
How do you know that Nascar uses Honda bearings? Or domestics period. . . thats funny.
Re: What bearings is everyone using for their high Hp Boost motors?? (integra_gsr98)
OEM bearings here. I dont trust anything but honda bearings. I like to retain as much OEM factory equipment that works in turbo applications, you are guarenteed quality and reliablility.
Re: What bearings is everyone using for their high Hp Boost motors?? (BrokenVtec)
im rebuilding my motor this spring........its a 2000 with 40,000 miles on it. while i have it apart, should i replace the bearings with a new set of OEMs, or are mine still good to go?
Re: What bearings is everyone using for their high Hp Boost motors?? (boosted hybrid)
anyone know by chance what color i need....2k civic Si (B16)
Re: What bearings is everyone using for their high Hp Boost motors?? (tony1)
Same here!
HT's Biggest Loser
Re: What bearings is everyone using for their high Hp Boost motors?? (ekb18c)
Same here!
Same here!
I got my motor rebuilt and i had them put oem's in for my boosting habits.
[Modified by 95c1v1cs1, 6:03 PM 2/7/2003]
