What else will I need?
Old Feb 5, 2003 | 04:02 PM
civ96's Avatar
Default What else will I need?
I was wondering what other parts I will need when I piece together my turbo kit. I know the turbo, manifold, wastgate, intercooler, bov, all the piping. Then for fuel I was going to get 65lb inj., AEM EMS or Hondata S200b, in-tank fuel pump, AEM fuel rail and regulator. Is there anything els I need? And what size wastegate should I get. I know I want a T3/T4 turbo with maybe the spark manifold or drag. Please let me know if I am missing anything I'm still kind of new to this Also instead of making another post I have one more question Is it bad to drive on a block that has a lower comp. for boost? Or with the upgraded fuel products? Thanks alot in advance
Old Feb 5, 2003 | 04:03 PM
MikeMAN's Avatar
Default Re: What else will I need? (supersi99)
I think the size wastegate u wanna get is a 35mm tial
mike
Old Feb 5, 2003 | 04:24 PM
civ96's Avatar
Default Re: What else will I need? (MikeMAN)
thanks bro
Old Feb 5, 2003 | 04:32 PM
MikeMAN's Avatar
no prob
Old Feb 5, 2003 | 04:43 PM
b16ahybrid's Avatar
as far as driving your car with low comp. pistons your fine it won't effect anything but power.And as long as your car is tuned you can drive with any fuel set-up.Stand-alone or not as long as your not runing to rich (i.e like throwing in really large injectors without any tuning) or to lean you'll be fine.
tial 35mm wg is what you need, works great for me and i believe it's rated up to 16 or 18psi before you need to upgrade to the 40mm
CTGrey06RSX-S
Jan 11, 2008 10:59 AM
BG-Teg
Apr 12, 2007 07:14 PM
95ATEG
Sep 29, 2004 09:34 PM
ATrin
May 27, 2004 02:42 PM
