Piping ?'s...
Old Feb 6, 2003 | 12:32 PM
TurboJesse
Guest
Posts: n/a
Default Piping ?'s...
I'm thinking about purchasing used piping from a drag III kit for a 94+ gsr..just wondering if this piping will fit my b16a Del sol...thanks
Old Feb 6, 2003 | 12:38 PM
CzanSOHC's Avatar
Default Re: Piping ?'s... (Mpir3)
there are some many varibles involed when using piping designed for a certain car with a certain turbo/manifold/ intercooler etc...
your best bet is make your own piping....it's cheaper and easier....
Old Feb 6, 2003 | 02:08 PM
boosted hybrid's Avatar
The piping is not going to fit right. The gsr throttle body sits lower than the b16a throttle body, so the piping is made to fit accordingly. Get LS, B16a or ITR piping and you will be fine for the throttle body fitment. BTW, intercooler piping doesnt fit 90% of the time if you dont use everything from the kit, and even if you do it still doesnt fit right. Go custom, or you begging for problems.
Old Feb 6, 2003 | 02:11 PM
Tofurky's Avatar
Default Re: Piping ?'s... (boosted hybrid)
custom
i should've done that.
you'd think using the drag piping for a gsr with work a hybrid. psshhhh.. after all the cutting & modifications, i should've just gone custom
Old Feb 6, 2003 | 03:47 PM
Jdm_Rice_Monster's Avatar
Default Re: Piping ?'s... (Ruckus138)
If you can get it cheap enough, modify it and use it. If not make your own.
95civlx
Jun 1, 2010 09:37 PM
Max500
May 26, 2007 08:28 PM
slo_crx
Jan 30, 2005 05:59 PM
swlabhot
Oct 13, 2003 12:29 PM
93LSivic
Nov 17, 2001 10:47 PM
