Greddy turbo timer... sort of works now..
Ok, so I finally got my turbo timer all hooked up right, and it works... sometimes.
The thing is, after I drive around for a while, and then park and shut the car off, the car shuts off right away, then if I start it back up and shut it off again it keeps running like it's supposed to.
What's going on here? Why do I have to shut the car off once first then re-start it to get the timer to work after driving? Could it be my ground?
Anyone got any ideas?
(Oh, and yes I do have it wired correctly 92-95 civics have a 5-wire ignition, not 4-wire)
Re: Greddy turbo timer... sort of works now.. (M-EJ1)
check, double check and then triple check your connections. Did you use a harness? Did you solder any necessary connections? Did you use a good ground?
ex_on_lsd
10-20-2007 06:20 PM
