map sensor
Old Feb 6, 2003 | 02:32 PM
ludelvr's Avatar
Default map sensor
If I'm not using a missing link on a d16z, do I just take off the map sensor and place a fitting a plastic fitting and wedge it into the hole where the stock map sensor goes? It's located on the throttle body itself, but I got that little check valve system from the drag kit and from what I understand, you simply wedge that little piece into the map sensor hole and make it air tight and then plug the map sensor into one of the vaccum ports off a T where the check valves are located.
Can anyone confirm this? thanks
methos713
Jun 11, 2007 12:43 PM
JustAnotherHonda
Aug 6, 2003 04:00 AM
turbojdm521
Jun 12, 2003 11:29 AM
