B16 boost question...
Old Feb 6, 2003 | 01:24 PM
UNDER PRESSURE's Avatar
Default B16 boost question...
What's the most I could boost on a stock B16 bottom end?
Old Feb 6, 2003 | 01:26 PM
b18bturbo's Avatar
Default Re: B16 boost question... (UNDER PRESSURE)
reasonably speaking you should be able to boost up to 8 psi safely. with out any modes done to the block. if you use a lower compression gasket you can even take it up to around 15-20 psi
Old Feb 6, 2003 | 02:04 PM
Default Re: B16 boost question... (b18bturbo)
Kool. Thanx bro.
Old Feb 6, 2003 | 02:18 PM
lazy bum shaughn's Avatar
So you're saying just a gasket can be a 7-12 psi difference?
Old Feb 6, 2003 | 04:34 PM
danl's Avatar
Banned
Default Re: B16 boost question... (lazy bum shaughn)
I don't think just a gasket will cause enough compression drop. Pistons too.....
Old Feb 6, 2003 | 04:48 PM
HXMan's Avatar
He means with proper tuning.
I had my b16a2 tuned for 10psi with hondata, stock compression...I didn't take it that high ever on the street on the track, but my tuner said it would be fine once in a while.
dragonfly2k3
Dec 30, 2007 04:17 PM
d16z6ef
Sep 3, 2007 02:34 PM
D1andOnly
Nov 27, 2005 05:00 PM
sunny79
Oct 20, 2002 02:58 PM
shotty
Aug 8, 2002 02:41 AM
