Turbo Oil Drain part #'s?
I just got my SC54 but I need the parts for the oil inlet and outlet. I want to go with all earls fittings if possible. What parts do I need? I need everyhting since all I have right now is the turbo. I also need a flange to I can tap my oilpan. Someone out there please help. I have to order all these parts so I wanns get everything the first time. Oh 1 more thing I just got the Greddy Oil Block adapter so that is were I plan on getting my oil supply from.
Re: Turbo Oil Drain part #'s? (18gTeg)
this is what i used for my oil line for my t3/t04e setup..dunno if its the same or not.
return line:
- 1/2" billet oil return flange
- 1/2" to -10an straight adapter #981610
- two -10an 45 degree "swivel seal" hose ends #804610
- -10an Perform-o-flex line (1 - 1.5 feet) #400100
- -10an steel weld on bung #967110
feed line:
- 1/8" bspt to 1/8" npt adapter
- 1/8" t-fitting (2 female openings, 1 male opening) available from autozone
- 1/8" npt to -3an straight adapter fitting #981603
- 40" -3an stainless steel line with hose ends #63010144
- 1/8" npt to -3an 90 degree fitting #982203
return line:
feed line:
Re: Turbo Oil Drain part #'s? (lilxvtecxpwr)
return line:
return line:
Thanks.
Do you have pictures of your setup?
Just wondering how you hooked up your stock oil pressure/oil pressure guage. I heard that some people move all this from the back of the block to somewhere else with another steel line to reduce stress on the back of the block due to all the connections being in one place.
Re: Turbo Oil Drain part #'s? (RyanAutry)
the last time i checked, summit had all the fittings but they didnt have the 3an feed line and were on backorder on the 10an return line. you might want to try www.anplumbing.com for the lines.
