Do b-series rods fit d-series? More specifically, LS rods in a d16y7
Wanting a cheap way to increase boost to about 13 psi! Will b-series rods hold that much? Could I use the pistons also? What else will I need to do that safely? The turbo is only good up to 13 so I now that needs to change to but what else? I am asueming spark. I have a msd btm for timing but no extra juice.
Re: Do b-series rods fit d-series? More specifically, LS rods in a d16y7 (CivicSoul)
yes the ls rod will fit but will require machining have you looked at a post on here
https://honda-tech.com/zerothread?id=267641 check that out very good alternative.
Re: Do b-series rods fit d-series? More specifically, LS rods in a d16y7 (b18bturbo)
I read a article back in the day, about someone using zc or old school ls rods in there d16. But I not sure about the 1.8 rods.
TylerLorenz
02-24-2010 05:15 PM
RACEPAK
07-14-2007 06:49 PM
