Attn: Arturbo
Old Feb 4, 2003 | 09:43 AM
Evil EG's Avatar
Default Attn: Arturbo
I got your old manifold revhard manifold and I had it welded up and powder coated black, do you remember what thread that egt or whatever hole that was so I can put a plug in it?
Old Feb 4, 2003 | 09:46 AM
b18bturbo's Avatar
Default Re: Attn: Arturbo (BVM)
he had greddy egt from what i remember
Old Feb 4, 2003 | 09:47 AM
Smashback's Avatar
Did you get it powder coated or ceramic coated? Powder coating will come right off when you fire it up..
Old Feb 4, 2003 | 10:16 AM
MotorMatrix.com's Avatar
I am a bad person
Default Re: Attn: Arturbo (Hatchblack)
i was thinking the same thing.
Old Feb 4, 2003 | 10:26 AM
justagsr's Avatar
Default Re: Attn: Arturbo (MotorMatrix.com)
He's not going to put it on his car guys, right?
Well, if so, maybe he got it jet hot coated?
Old Feb 4, 2003 | 10:28 AM
Smashback's Avatar
Default Re: Attn: Arturbo (justagsr)
It looks like it's been sandblasted and left bare, but if it's powder coated, it will burn off pretty quick.
Old Feb 4, 2003 | 10:56 AM
Evil EG's Avatar
it was powder coated high temp black is what the guy told me and says on the recipt. I was not aware it would fall off but thats not my question. I want to know what thread size the hole is so after work I can go get a plug.
[Modified by BVM, 1:57 PM 2/4/2003]
Old Feb 4, 2003 | 11:04 AM
Evil EG's Avatar
I just called the guy that powder coated it and he said he uses an "organic powder" that can withstand 1000 degree F temperatures. He had four other headers for some v8 cars that he powder coated also....
Old Feb 4, 2003 | 11:17 AM
boostaholic's Avatar
Your manifold is going to get hotter than 1000 degrees at times. I used 1200 degree VHT paint but it flaked off, the 1500 is holding up just fine. If you have a local bolt or fastener specialty shop, just take your manifold there and they will be able to find the size and thread pattern for your plug.
Old Feb 4, 2003 | 11:22 AM
CzanSOHC's Avatar
Default Re: Attn: Arturbo (boostaholic)
if he used an GReddy EGT gauge prob...then the hole is a 1/8" NPT with 27 thread pitch.
Old Feb 4, 2003 | 01:23 PM
rjardy's Avatar
Default Re: Attn: Arturbo (CzanSOHC)
manifold looks good, im glad that our trade worked out for you. try a 1/4 inch plug, that may work, not to sure.
Rob
Old Feb 4, 2003 | 01:39 PM
Smashback's Avatar
Default Re: Attn: Arturbo (rjardy)
Usually 1/8 NPT....I think your coatings guy is confused about his products, but OK
N/A headers are usually fine with 1200 degree ceramicoat but turbos and turbo manifolds usually get treated with 2000 degree (next step from 1200 for ceramicoat)
Old Feb 4, 2003 | 02:56 PM
earl's Avatar
Hard to tell from pix, if not 1/8 pipe, could be 1/4 pipe.
Old Feb 4, 2003 | 03:35 PM
Flamenco-T's Avatar
Default Re: Attn: Arturbo (earl)
greddy egt
1/8" NPT, 27 threads pitch
[Modified by Flamenco-T, 6:35 PM 2/4/2003]
boostdummy
Jan 19, 2006 09:06 PM
RACEPAK
Nov 6, 2004 04:43 PM
PA MATT
Aug 2, 2004 10:11 AM
PM-Performance
Jan 3, 2003 09:41 PM
BodyKits NW
Feb 14, 2002 10:07 PM
