ok real jackass question
Old Feb 4, 2003 | 07:51 PM
vha27's Avatar
Default ok real jackass question
ok so the colder the air the more power correct, hahaha what if u had ur a/c full blast, but instead some how routed all that cold air into the intake rather than using it to stay cool during the summer, would u lose more power having a/c on that how much cold air ur supplying, or could there actually be an increase?, always wanted to ask this question
Old Feb 4, 2003 | 07:57 PM
genop's Avatar
Default Re: ok real jackass question (vha27)
I have never heard of anyone trying that, but I can assure you that you probably wouldnt see any gains. The loss just by having the AC on would probably negate any gains.
Old Feb 4, 2003 | 08:02 PM
vha27's Avatar
now what if u had some type of motor , just say somehow it was possible, driving the a/c pump, i mean its cold cold air right?! i figure u cant really get this much cold air from ne other source, or am i wrong, or will a water-air ic with ice be cooler, just wondering
Old Feb 4, 2003 | 08:06 PM
ion_four's Avatar
There are intercoolers that use a refrigerant system to cool air temps below ambient. check out http://www.bobnorwood.com and there's a ferrari on there with a HUGE centrifugal supercharger and an intercooling system like an air conditioner (no, it's not a water to air, in case you ask) This is something that I may look into in 2-3 years if I win the lottery and have nothing better to do
Old Feb 4, 2003 | 08:09 PM
vtecbluesi's Avatar
Default Re: ok real jackass question (ion_four)
if i remember right the new lightnings that are coming out have the supercooler. what that is is obviously a supercharged engine, but the ac pumps cold air into a resevoir, then when the driver goes wot it dumps into the intake or engine somewhere and acts as kind of a nitrous effect.
Old Feb 4, 2003 | 08:13 PM
bottlefedb18c1's Avatar
well maybe if you have a elevtric motor that turns the A/C pump and have the condensor inside of something like a air to water so there is no drag on the cars motor just on the electic motor
Old Feb 4, 2003 | 08:59 PM
tony1's Avatar
Default Re: ok real jackass question (boostfedb18)
The problem with actually feeding the conditioned air to the motor is that the compressor can't supply enough air for a motor at WOT. It may help by having a little cool air, but i'd rather have ac INSIDE my car and a turbo for the power...
Old Feb 4, 2003 | 09:34 PM
MiraiZ's Avatar
Default Re: ok real jackass question (tony1)
didn't someone post an article about a ford truck with a similar system...it routes cold air from the a/c to the intake at WOT...
SupaMonkey
Apr 14, 2009 02:18 PM
SandSanta
10
Jun 12, 2002 07:17 PM
tofuboi
May 6, 2002 03:01 PM
