NOS sneaky pete kit
just curious if anyone here is running the NOS brand Sneaky Pete nitrous set up.. i'm just curious how you get that to work on your car, because the site says it's made for a carburated engine. i would like to get one of these little set ups, but i don't know if it will work w/ my car, but i hear it has been done.
thanks
thanks
You may be able to do it with bigger injectors and 2 pots. Tuning could be acomplished with a pot inline with the map and hitting the switch would go to the other pot also inline, but not as high of resistance.
-Dustin
-Dustin
You can use the sneeky pete, but you will have to tune your car to run rich enough so you don't detonate to all hell when you spray. Basically you'll be sacrificing power when you are off the bottle, in order to have minimal gains on the bottle. If you use a single fogger kit you can still hide it just as well, but you won't have to tune your car to run rich. Instead you can have an AF closer to 14.7 all of the time, on and off the bottle.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by laughinxxx »</TD></TR><TR><TD CLASS="quote">You can use the sneeky pete, but you will have to tune your car to run rich enough so you don't detonate to all hell when you spray. Basically you'll be sacrificing power when you are off the bottle, in order to have minimal gains on the bottle. If you use a single fogger kit you can still hide it just as well, but you won't have to tune your car to run rich. Instead you can have an AF closer to 14.7 all of the time, on and off the bottle. </TD></TR></TABLE>
I run A/F mixture if 13:0 all the time... Would that be safe with the Sneaky Pete system?
I'm looking to buying one of these...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegunderpressure »</TD></TR><TR><TD CLASS="quote">Ofcourse, you will just need to buy the jets. However for that shot, I would stick with a dry kit from Zex. </TD></TR></TABLE>
A dry 25 shot is pratically a sneaky pete...
itll work fine
we nos'd the **** out of my frends sohc motor, a vtec-e motor with a tiny throttle body
that motor held up and pulled
we simply used the jets that came with it, just looked at the 1 with the biggest hole and shoved it in bkuz we dint know how much of a shot each was and we did nothing for fuel
another way to do it is, by barely opening the bottle, just slightly so the nos ooze's out instead of turning it all the way open
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic »</TD></TR><TR><TD CLASS="quote">
A dry 25 shot is pratically a sneaky pete...</TD></TR></TABLE>
You do not understand. The Sneaky Pete kit is only going to introduce nitrous into the engine, no more fuel what so ever. A dry Zex kit will inrease pressure at the fuel pressure regulator and therefor inject more fuel along with the nitrous, keeping you nice and rich.
