BOV Vaccum Line + Boost Gauge Install, Quick Q's
Quick Question about installing these both:
Could I just T-off ( a double T) where the hose for the stock FPR goes into the IM, and hook the vaccum line from the BOV to this and run my Boost gauge off of this?
thanks for any help/info!
mike
mike
Re: BOV Vaccum Line + Boost Gauge Install, Quick Q's (MikeMAN)
yeah you can tee it off the FPR along the BOV also. However, it is not recommended. You can tee the BOV off the brake booster vacumm. Try a search under archives. Should find plenty of information. Hope this helps
Re: BOV Vaccum Line + Boost Gauge Install, Quick Q's (khang77642)
vacuum is vaccum, you cna tee it off anywhere you like..
you can also tap it to EVAP vac hose, on the evap solenoid, there are two hoses, tee it off the hose that goes back to the intake manifold
stan
stan
