relay diagram for inline fuel pump
Old Feb 3, 2003 | 10:53 PM
ludelvr's Avatar
Default relay diagram for inline fuel pump
Hey guys, does someone have that sweet diagram for wiring up an inline fuel pump? I did a search and couldn't find it! thanks!
Old Feb 4, 2003 | 12:02 AM
boostaholic's Avatar
Default Re: relay diagram for inline fuel pump (ludelvr)
Compliments of Arturbo
Old Feb 4, 2003 | 12:04 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: relay diagram for inline fuel pump (boostaholic)
Old Feb 4, 2003 | 12:07 AM
ludelvr's Avatar
Default Re: relay diagram for inline fuel pump (Arturbo)
Once again Art, you are da man!!! thanks guys!!
Old Mar 2, 2005 | 07:48 PM
dkim48's Avatar
bringing this back from the dead...does anyone have a diagram that shows. TIA
Old Mar 2, 2005 | 07:49 PM
dustin's Avatar
Default Re: relay diagram for inline fuel pump (dkim48)
You can just wire it to the main relay. Or you can use an external relay if you want..
Old Mar 2, 2005 | 07:54 PM
dkim48's Avatar
Default Re: relay diagram for inline fuel pump (dustin)
well i got a used inline fuel pump that came with a relay and wires...i just need to know what goes where. TIA
Old Mar 2, 2005 | 07:59 PM
dustin's Avatar
Hmm most relays have a diagram on them. Something like:
Relays are magnetic switches. So if you put power through 85 and 85... it flips the switch.
So for example send pin 85 to ground, 86 to your input power (can be triggered from a low current output, hence the point of running a relay in the first place), 30 to the battery... and 87 to one side of the pump. The other side of the pump goes to ground.
Old Mar 2, 2005 | 08:11 PM
dkim48's Avatar
cool. i'll give that a try tomorrow
Reelizmpro
Jul 10, 2005 06:33 AM
tyflip2
Jun 22, 2004 09:37 AM
ludelvr
Aug 23, 2002 05:40 PM
