Is this a 3 bar MAP (pic inside)
Old Feb 4, 2003 | 07:26 PM
98civicEX's Avatar
Default Is this a 3 bar MAP (pic inside)
Off a late 80 pontiac sunbird turbo
Old Feb 4, 2003 | 07:31 PM
boostaholic's Avatar
Default Re: Is this a 3 bar MAP (98civicEX)
Is there a part number on it?
Old Feb 4, 2003 | 07:32 PM
98civicEX's Avatar
Default Re: Is this a 3 bar MAP (boostaholic)
On the top of the part is "466". Elsewhere on the unit are the numbers "012 8260".
(my fault for not adding before
Old Feb 4, 2003 | 07:34 PM
hoya_10fintec's Avatar
LOOKS like it...
Old Feb 4, 2003 | 07:45 PM
MiraiZ's Avatar
Default Re: Is this a 3 bar MAP (hoya_10fintec)
could be the 2 bar tho...they look a lot alike if not identical
Old Feb 4, 2003 | 07:46 PM
Speed PHreak's Avatar
It's most likely a 2 Bar MAP. Most GM MAP sensors all look the same. GM uses them on most of their turbo cars as well. Unless that car boosts over 14.5psi stock then it's got no need for a 3 bar MAP. The fabled 3 Bar MAP sensor only comes on one GM car stock -- The 89 Turbo Trans AM, which ran 16.5psi from the factory.
[Modified by Speed PHreak, 11:48 PM 2/4/2003]
The DX Rex
Sep 18, 2009 08:56 PM
b18 hatch mike
Aug 29, 2008 09:33 PM
hondatm
Jan 19, 2007 05:31 PM
turboeg77
Feb 26, 2006 04:18 PM
littlebluecrx
Apr 1, 2002 08:20 PM
