What Fuel rail and reg should i get...
550cc injectors
bout 10 psi
hondata
i was thinkin AEM fuel rail and regulator.. how does it do under boost..
bout 10 psi
hondata
Re: What Fuel rail and reg should i get... (BoostedH23a1)
there regulators dont like high fuel pressure you can ask DIREP for more info on that ****
Re: What Fuel rail and reg should i get... (b18bturbo)
I've heard of people having problems with the aem and fmu's (high fuel pressure) but i've yet to have a problem with mine...
Apparently the problem was due to using an output oraface that ws to small (you need to use the larest one thats suplied) [
Re: What Fuel rail and reg should i get... (b16ahybrid)
will an aeromotoive 13101 fuel reg work?
[Modified by BoostedH23a1, 4:34 PM 2/5/2003]
what part number (earls fitting) would i need to connect this reg to the aem fuel rail and the reg to the stock return line?
also what is the difference between the 13109 and the 13101 fuel reg from aeromotive someting about A1000 and A1000-6 whats that
yes run -6 line to the fpr or get aem rail and run it that way. much easier since aem comes with fiting so you cn run an on the neds
ok sounds like its the aeromotive 13101 and the aem rail.... on the AEM rail it says -8AN and on the reg it says -10AN they do make an adapter right...
yes they do.. you need std thered to an tis pretty simple to get you can run -8 feed to the rail from the fuel filter and -6 for your return to the fpr to the fuel return to the tank
what size is the rubber line that comes off the stock FPR is that 5/16 line? also
need to know the size of this thread in this pics (supply line for fuel rail)
and will i need to get a 90degree AN fitting for this (not the EGR is in the way)
[Modified by BoostedH23a1, 6:21 PM 2/5/2003]
These articles might help you...
https://honda-tech.com/zerothread?id=228989
https://honda-tech.com/zerothread?id=370570
thanks to Art
-deepsi
thanks to Art
-deepsi
Re: What Fuel rail and reg should i get... (DeepSi)
something must be wrong with my search button. i try prelude and search in prelude forums.. says no criteria was found.. pos
Dunno how high the pressure we're talking about here is, but I'm running an AEM rail and regulator at 53psi idle on 450cc's at 9lbs and it's doing just fine.....
With 550's and a hondata on 10lbs you might need like 45ish psi of fuel pressure at idle to keep the duty cycle down.....SX or Aeromotive is overkill IMO, and all the lines and fittings you'll need to make it work are $$$$$$
Brian
Brian
might as well do it right the 1st time...
Brian
Re: What Fuel rail and reg should i get... (Firedrake)
why can't you just use the stock fpr and fuel rail? as soon as I get some better management, I'm ditching the adjustable reg.
Re: What Fuel rail and reg should i get... (QCKGSR)
hey in this pic here the one on the bottom is the return and the 2 on the ends that are horizontal are the feeds right... only use one of course...
that correct?
that correct?
