Direct Port Nitrous or Single Intake Nitrous
Old Feb 5, 2003 | 08:17 AM
Lewie's Avatar
I'm here for the gangbang!
Default Direct Port Nitrous or Single Intake Nitrous
I am looking into getting nitrous which I want to use until I get my turbo kit, then I am going to use the nitrous to spool the turbo. But, should I get direct port nitrous to give me a lot bigger boost or should I just get a single 50 or 75 shot? Also, does anyone have a nitrous setup that they would recommend. I was looking into ZEX or NX
Old Feb 5, 2003 | 08:21 AM
GSRwBOOST's Avatar
Default Re: Direct Port Nitrous or Single Intake Nitrous (lewie4)
Are you gonna build your block?
Nitrous to spool the turbo?? what size turbo are you gonna need to help do that?
Save your money for the extra stuff you will need for the turbo....
Turbo's spool faster than you think.... unless your gonna have a turbo the size of your gastank mounted on the front..
Old Feb 5, 2003 | 08:39 AM
Lewie's Avatar
Default Re: Direct Port Nitrous or Single Intake Nitrous (GSRwBOOST)
yeah, eventually i am going to build the block....but i just wanted a little boost off the line just for fun until my turbo kicks in
Old Feb 5, 2003 | 12:02 PM
B16sR4Kids's Avatar
Well to answer your question I would say.....Get a small shot of Zex. Direct Port is usually for people who use only nitrous since you can spray twice as much than a Dry kit like zex.
Old Feb 5, 2003 | 01:53 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Your asking for traction problems Just stick with the 55 shot in the zex kit. If you need any tech info i can help you. It no to hard though. If your going turbo eventually just get a small shot. It will wake the engine up i promise. Filling the bottle will get very old and expesive. Turbo never has to be filled up. That's why i switched.
Old Feb 5, 2003 | 02:04 PM
rOby's Avatar
Default Re: Direct Port Nitrous or Single Intake Nitrous (HybridcivicLS-T)
normally i would say direct port but for u id say single fog
Old Feb 6, 2003 | 06:11 AM
Lewie's Avatar
Default Re: Direct Port Nitrous or Single Intake Nitrous (rOby)
Thanks, my friend had a ZEX 75 shot that we installed on his integra....I think I am going to do the same, but maybe only a 55shot.
karmadhi
Mar 12, 2014 08:23 PM
guessohw
Jan 12, 2009 07:39 AM
Legendaryyaj
Nov 18, 2003 02:26 PM
Cow
Oct 18, 2002 01:33 AM
