Spark plugs have often do you change them??
I have NGK copper race spark plugs 1 stage colder on my boosted sohc i have already done 20000kms on them wondering when people reccomend I should change them???? Is there a way to tell if there getting worn out... Cheers
Re: Spark plugs have often do you change them?? (turbozxi)
IIs there a way to tell if there getting worn out... Cheers
I personally, usually change my plugs out every 3,000 miles or 5,000 km.
Re: Spark plugs have often do you change them?? (ekb18c)
Sorry I obviously didn't make it clear, what are the signs to look for in a worn plug?
Usually lot's of deposits, carbon, poor performance, hard starting, hessitation.
I usually change mine about every 2k miles or sooner (i'm always swapping even if they are fine) i go through them like oil changes thats why i run ngk's except rite now i have some zex plugs in there (decided to try them this week).....
Take out the plug and take a look.
maybe this will help There is actually a bunch of sites online that give you tips on reading spark plugs.
Re: Spark plugs have often do you change them?? (piscorpio)
about every oil change is a good time to change them so 3000 miles sounds about right. even though i change my oil alot sooner than that
You can tell pretty easily, the electrodes get worn down. Check the gap, if it's off by much, you should replace them for the best performance.
ILLICON3000
09-20-2004 07:45 AM
Snafu-Si
06-06-2003 01:51 AM
