Fitment Problems w/ Inline Pro Manifolds
Old Feb 5, 2003 | 05:18 AM
integranator's Avatar
Default Fitment Problems w/ Inline Pro Manifolds
I have recently aquired a t3/t04e turbo-- and now i'm looking for a manifold. I really want an Inline pro manifold, but i've heard there are serious fitment issues with them? Why are there fitment problems, please explain the difference in bolt patterns cas' i'm a n00b when it comes to this! thnx!! also, which manifold do you think i should get for a street application w/ 8psi?
Old Feb 5, 2003 | 05:33 AM
Mase's Avatar
Default Re: Fitment Problems w/ Inline Pro Manifolds (integranator)
I know first hand the fitment problems w/ the inline pro manifold and the 4 bolt garrett turbos.
Now, Its only w/ the 4 bolt garrett housings, If you have a 5 bolt turbo, then you are fine, it will fit without much off the block, but if you are like me, and have the 4 bolt turbo, you have to shave a **** load off the block.
so the question is: Do you have a 4 bolt or 5 bolt exhaust housing?
Old Feb 5, 2003 | 05:42 AM
Default Re: Fitment Problems w/ Inline Pro Manifolds (Mase)
I don't know yet I JUST ordered a garrett turbo from cheap turbo .com
Old Feb 5, 2003 | 05:46 AM
Mase's Avatar
Ok, its the four bolt.
You can do one of a few things....
1. Buy the inline pro manifold...Shave the block like I did, its a Pain in the ***, but it works,
2. Buy a manifold that was designed for the 4 bolt turbo (i believe maxrev is one).
3. Sell this turbo and buy a kick *** Precision Turbo from Arturbo and use the inline pro (which also can be bought from Arturbo).
What ever you decide, dont rush things. I am happy w/ my car right now, it only sucked while you are installing it
Good luck, and let us know if you have any other questions.
Old Feb 5, 2003 | 05:59 AM
I haven't heard much about the precision turbo's??
Old Feb 5, 2003 | 06:04 AM
Mase's Avatar
Talk to Arturbo about them, they are extremely good quality, and a very decent price.
Old Feb 5, 2003 | 06:12 AM
yellowsub's Avatar
https://honda-tech.com/zerothread?id=402894
Old Feb 5, 2003 | 06:18 AM
trbob16a's Avatar
Default Re: Fitment Problems w/ Inline Pro Manifolds (yellowsub)
If you don't want a/c you can just turn it around and you'll be able to fit almost anything in there. I put a garrett 4 bolt 60-1 in my car, with a filter, and didn't shave, cut, or beat anything. This is a b16 in a 92 cx.
Old Feb 5, 2003 | 06:24 AM
PM-Performance's Avatar
Default Re: Fitment Problems w/ Inline Pro Manifolds (trbob16a)
i have the maxrev and a garret t3/04e 60 trim 63 ar , and mine fit beutifully the standard mounting way
Old Feb 5, 2003 | 06:35 AM
KC GSR's Avatar
Call them up and cancel your order before they ship it and order a Precision from Art
Old Feb 5, 2003 | 07:23 AM
SiRkid's Avatar
Default Re: Fitment Problems w/ Inline Pro Manifolds (KC GSR)
i was thinking.. ANYWORD on whether INLINE PRO is making/modifying their manifold to have one for the 4 bolt turbo's?Art?
Old Feb 5, 2003 | 07:47 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Fitment Problems w/ Inline Pro Manifolds (SiRkid)
No, I doubt it because they run Precision turbos also.
But to the original poster, read my article that someone just posted titled " Garret 4-bolt vs. 5-bolt."
art
Old Feb 5, 2003 | 09:43 AM
Default Re: Fitment Problems w/ Inline Pro Manifolds (Arturbo)
how do i find the prices of precision turbo's?? do they have a website??
Old Feb 5, 2003 | 11:03 AM
rOby's Avatar
http://www.precisionte.com
Old Feb 5, 2003 | 11:30 AM
ITR981002's Avatar
Works for me!
Old Feb 5, 2003 | 01:41 PM
95c1v1cs1's Avatar
Default Re: Fitment Problems w/ Inline Pro Manifolds (gothatch)
This may be a dumb question but how does a five bolt mount up to a 4 bolt manifold? Or vice versa? Thanks
Old Feb 5, 2003 | 02:21 PM
inspyral's Avatar
Default Re: Fitment Problems w/ Inline Pro Manifolds (95c1v1cs1)
It's the dp flanges that are different, not the turbine inlet flange(which mates tot eh manifold). So as long as you have a turbine that matches your manifold, it doesn't matter how many bolts the dp flange has. The other difference, besides having a different number of dp bolts is the CHRA offset, which Art goes into detail about in his write-up.
Old Feb 5, 2003 | 03:08 PM
95c1v1cs1's Avatar
Default Re: Fitment Problems w/ Inline Pro Manifolds (inspyral)
Thanks.
So If I get a t3/t04e turbo I should get the T3 manifold from Inline pro or the T4 manifold? BTW, sorry about all the newbie questions. Just starting my research for this part of my project. I appreciate the responses.
Old Feb 5, 2003 | 03:51 PM
yellowsub's Avatar
T3 manifold because a t3/4 uses a t3 exhaust housing.
TooFastVTEC
Aug 10, 2012 05:29 AM
JDMCRX
Jan 12, 2007 07:25 AM
rextec
Dec 11, 2003 05:56 AM
tegasaurus
Jul 24, 2003 03:48 AM
DimSum321
Mar 17, 2003 04:13 PM
