finaly got my turbo on has a few ?s need some help
ok my set up is b16 sir1 t3 air research turbo, eclipse 1gbov, 450 dsm ingectors and smc+ i have an msd btm bt its not hooked up yet. ok when im driving the car it feels slugish underboost. and i can;t really feel a differance in power than before i was boosted. do u hve to much fuel going in and its causing it to be sluggish? also when i let of the gas or im coasting in 5th the air/fuel meter goes all the way down to lean. what could cause that and how do i fix it? thanks
Re: finaly got my turbo on has a few ?s need some help (MyWhiteCivic)
im running at5psi it gets their pretty quick it just doesn't fell like their is any more power added.
Re: finaly got my turbo on has a few ?s need some help (bmcc72)
the reason why ur A/F ratio goes to lean when u let off is because u aren't pressing the gas
( had an autometer one, and it does the same thing )
mike
mike
Re: finaly got my turbo on has a few ?s need some help (MikeMAN)
so is it ok that it does that? and will it hurt my engine?
also i am creating boost so i don;t think their is a leak anywear but im going to check anyway.
Re: finaly got my turbo on has a few ?s need some help (turbod16y8)
if you running sluggish you maybe running rich since you have a pretty good size injectors
[Modified by luckypon7, 3:09 PM 2/11/2003]
MSD 6AL FOR SALE $180+SHIPPING had for 3 months still works, just got new msd 6btm in place
Re: finaly got my turbo on has a few ?s need some help (jz)
well i found out sense my speedo still isn;t working my ecu is in limp mode so its running extremely rich all the time. im ganna take it to the dealer and have them figure it out. if i fix the speedo and have no codes i should be able to tune the smc+ and fix the air/fuel ratio and get some power out of it. im almost done with my intercooler so as soon as i get the speedo fixed ill be running around 8psi.
thanks for the help
thanks for the help
Carlos 88CRXSi
11-12-2010 10:16 AM
