swapping TD06-20G turbine housing for the TD05/TD06 hosuing from my 18G
Guest
Posts: n/a
this guy i know has a TD06-20G that he had on his Eclipse and since he is selling the car, he told me he'd sell me the turbo. the thing is, i am not sure i want to use the same style downpipe as the DSMs, so, would i just be able to swap out the turbine housings, since mine is a hybrid??
Re: swapping TD06-20G turbine housing for the TD05/TD06 hosuing from my 18G (Boosted97Lude)
I would think you would have to find out the trim of the turbine wheel on the greddy kit and see if it matches up, or try to find out the a/r or CM2 of the turbine housings, and see if they're close..or you could just try it... Lemme know!!! Also, you would not be able to use the DSM style downpipe, as the bolt pattern is different, and the mounting flanges for the turbine housing are also completely different... Swapping housings is your only option I believe, you may want to call Majestic Turbo, or Turbochargers.com or something also, they may be able to help.
NZXTInerTia
05-12-2013 07:10 PM
