Hondata obd 0
Old Feb 5, 2003 | 09:04 PM
havok hybrid's Avatar
Default Hondata obd 0
hey all.. i have a d15 sohc turbo on 10 psi.. i want to run a hondata.. can i run a pwo or pr3 ecu or setup on a sohc non vtec.. with a hondata... please help me ..
what will i have to do .. ?
Old Feb 5, 2003 | 09:13 PM
BudaKai's Avatar
Default Re: Hondata obd 0 (havok hybrid)
With Hondata I thought you could run any EDU because basically you're rechipping it to work with a new set-up.
Old Feb 5, 2003 | 09:16 PM
Speed PHreak's Avatar
Hondata will work, you may wanna look into a Zdyne tho. http://www.zdyne.com
Enjoy
Old Feb 5, 2003 | 09:27 PM
V3locity's Avatar
if youre going to stay OBD0 go with the ZDYNE
if you want the hondata, switch to OBD1
Old Feb 5, 2003 | 09:53 PM
UberTeg's Avatar
Default Re: Hondata obd 0 (illdezignzls)
if hes going to use the PR3, he cant use a zydyne. PR3 is obd-0 board, with obd-1 brains. I'm not sure if hondata supports it or not.
Old Feb 5, 2003 | 10:08 PM
Kwuaymaikrup's Avatar
Default Re: Hondata obd 0 (UberTeg)
He will just have to use the older programs, ie; 2b,3b,3b ect. I am doing the same in my non OBD DA.
HTH
Ryan
Old Feb 5, 2003 | 11:49 PM
ImportReview
Guest
Posts: n/a
Default Re: Hondata obd 0 (Kwuaymaikrup)
I have done it before many times.
Problem is on your car is that you can't lamda datalog easily, so I have to do it from my readout only.
Which is really good still, but not super duper duper accurate at all throttle positions.
But I can still tune it good.
Jeff
Old Feb 5, 2003 | 11:51 PM
So.. let me get this staright.. i can run hondata .. ?... for obd 0 i have pm6 now.. DO i have to run pr3 power... and if so.. CAN I MAKE A PR3 or PWO RUN A SOHC turbo set... i have already paid for the hondata.. and i dont want to switch to obd1..unless that is the last option
Old Feb 6, 2003 | 04:51 AM
Charlie Moua's Avatar
TTT ive always wanted to know that too... i thought the boost options was only for OBD1 cars?
or are you entending on runing HONDATA pr3 na tunning to compaste for the turbo?
Old Feb 6, 2003 | 05:41 AM
ricodemus's Avatar
Default Re: Hondata obd 0 (Charlie Moua)
you can run the Hondata 2b for the PW0 and PR3 ecu's. I don't know how it will work for a sohc because its for a dohc vtec motor.
Old Feb 6, 2003 | 07:16 AM
Any one help me.. ?.. can a pr3 or pwo be maped to run a non vtec motor..?
Old Feb 6, 2003 | 10:31 AM
ImportReview
Guest
Posts: n/a
good point, I have only done all motor cars.
I do not know if turbo is going to work.
Jeff
Old Feb 6, 2003 | 01:12 PM
Default Re: Hondata obd 0 (ImportReview)
Not to sure if it can. Try www.c-speedracing.com they have a Hondata forum and rule at tuning these things. I learned alot from them. Check it out, I hope it helps a little. Goodluck.
Ryan
Old Feb 6, 2003 | 01:48 PM
Sonny's Avatar
Yes, you can do it. I ran a PR3 with a 3 bar map sensor on a boosted 2nd gen CRX Si w/B16A swap. It can control a SOHC engine with no problems either. You will get much more out of the system if you convert to OBD1, but PR3's can be made to work with Hondata reasonably well.
Sonny
Old Feb 6, 2003 | 03:39 PM
Default Re: Hondata obd 0 (Sonny)
thanks man... that is all i was looking for.. i already paid for the hondata.. can i convert the hondata .. back and forth from obd0 to 1
Old Feb 7, 2003 | 01:33 AM
BUMP!!!.. CAN I RUN A PR3 ECU *hondata* to run a sohc non vtev setup
Old Feb 7, 2003 | 09:54 AM
HIPEmotorsports's Avatar
The Obd0 still works of version 2.5 of the rom editor. You cannot run a non vtec motor with a pr3, reason being is that it looks for knock sensor,vtec solenoid and vtec pressure switch. As far as physically running the car goes you can bump the vtec to 7000 rpm and tune the map on the low speed cam for your application but you will have a check engine light on at all times and it will not run the greatest. In the version 3.0 you can disable knock sensor and vtec pressure switch but you will still get the vtec solenoid code. If i was you i would not do it. HTH
Old Feb 7, 2003 | 10:04 AM
Sonny's Avatar
Default Re: Hondata obd 0 (HIPEmotorsports)
Doug has stated that it it IS possible to run a non-VTEC engine with the PR3. You will need to do some things to keep the ECU happy so that it won't throw codes for the KS and VTEC solenoid, but it can be done.
Sonny
Old Feb 7, 2003 | 10:05 AM
true's Avatar
Do yourself a favor and convert your crx to obd1. Anyone who has done it with a boosted motor would never consider going back. Once you purchase your Hondata system (s200 etc..) you can move it from ECU to ECU. The only issue is that you cannot buy an s200 PR3. If you got a pr3 4b though, you could just move it over to a p28 ECU.
danieljweaver
Mar 21, 2007 08:29 PM
hotimportcrx
Jun 23, 2005 11:06 PM
Apollo
Oct 21, 2003 09:59 AM
hi mom
Sep 16, 2003 09:40 PM
The Early November
Jan 3, 2003 11:58 AM
