pipe cutter.. where do you get em.
Old Feb 5, 2003 | 02:45 PM
DIY_Racing's Avatar
Default pipe cutter.. where do you get em.
Ok, i went to home depot to pick up one of those pipe cutters. The kind you mount on a piece of pipe, tighten it down and turn it until it cuts through.. AlOT easier then doing it by hand.... BUt when i was at home depot all the had was 2 1/8 size was the biggest.. i need 2 1/4 minimum...
anyon know where to ge ta bigger one??
Old Feb 5, 2003 | 02:50 PM
gtcali's Avatar
Default Re: pipe cutter.. where do you get em. (DIY_Racing)
I remember seeing some in the JC whitney catalog.
Old Feb 5, 2003 | 02:52 PM
LS-hatch's Avatar
All i can say is check some more home improvement places, and see is there are any plumbing supply stores in your area.
Old Feb 5, 2003 | 02:54 PM
95hybridcivic's Avatar
Default Re: pipe cutter.. where do you get em. (LS-hatch)
They have a couple different kinds at http://www.northerntool.com just type in pipe cutter in the search area they range from 9-20 bucks.
Old Feb 5, 2003 | 02:55 PM
shortyz's Avatar
any plumbing store will have them..
also if you are flaring make sure u got all the burr off or it will leak like a sieve.
Old Feb 5, 2003 | 03:20 PM
Jdm_Rice_Monster's Avatar
Default Re: pipe cutter.. where do you get em. (shortyz)
band saws work great too.
Old Feb 5, 2003 | 03:35 PM
SiRkid's Avatar
Default Re: pipe cutter.. where do you get em. (JdmRiceMonster)
canadian tire..oh wait..thats here.
Old Feb 5, 2003 | 03:44 PM
true's Avatar
Del, I'm assuming you want to cut intercooler and exhaust pipes...you don't want a plumbing pipe cutter for that. You want an abrasive chop saw. For example: http://www.weldingmart.com/Qstore/p000558.htm Home depot and Menards have them too. Band saw works well too, but for quick easy rough cuts you can't be a 14" cut off saw.
Old Feb 5, 2003 | 03:50 PM
DIY_Racing's Avatar
Default Re: pipe cutter.. where do you get em. (true)
YA, ID LOVVVE to have one of those.. i just dont want to spend 160 bucks to cut pipes ya know...
Del
Old Feb 5, 2003 | 04:57 PM
Phoenix GSR's Avatar
you can get a smaller chop saw from northern tool or harbor freight for about $30.. they only have 6" and 7" in that price range, but they will do fine for personal turbo related stuff!
Old Feb 5, 2003 | 05:05 PM
true's Avatar
Default Re: pipe cutter.. where do you get em. (Phoenix GSR)
Yeah, you can defeintly get a chop saw cheaper then the link I posted...that was just a quick and easy find when searching cut off saw on the net.
Old Feb 6, 2003 | 04:55 AM
http://www.northerntool.com/webapp/wcs/stores/servlet/CategoryDisplay?categoryId=93576&storeId=6970&cata logId=4006970&langId=-1&PHOTOSn
there is one for $39 6.5"
[Modified by Phoenix GSR, 7:56 AM 2/6/2003]
Old Feb 6, 2003 | 05:02 AM
dennis's Avatar
Think my dad paid like $50 or less for this from harbor freight. The accuracy of the angle scales on it are a joke, but it cuts.
PolishSasquatch
Welding / Fabrication
Apr 8, 2008 02:57 PM
r0yal
Apr 19, 2006 07:03 PM
FURACERMAN
Jan 6, 2006 06:32 PM
redzcstandardhatch
Dec 15, 2005 06:13 AM
k193sup
May 22, 2002 07:38 AM
