Turbo Break-In Guidelines
Old Feb 5, 2003 | 05:01 PM
B94Cast's Avatar
Default Turbo Break-In Guidelines
B4 anyone indicates to do a search, I have. What I turned up seemed to be mostly conjecture.
My questions are:
1. What is the best length of time to break in your turbo?
2. Should you not boost at all?
3. Should you boost just a bit occasionally?
I have a newly installed Drag Gen3 turbo kit. Any input would be appreciated, and reference to any resources would also be appreciated.
Thanks!
p.s. My local tuner shop indicated that break-in takes 500 miles, and I should stay beneath 4KRPMs, and never boost.
Old Feb 5, 2003 | 06:11 PM
DeepSi's Avatar
Default Re: Turbo Break-In Guidelines (B94Cast)
i dont think there is a break in period for turbo kits. at the beginning just listen for pinging and detonation.
Old Feb 5, 2003 | 07:35 PM
boostedsol's Avatar
Default Re: Turbo Break-In Guidelines (DeepSi)
When i got mine, i drove it around a bit and tried to listen for any thing that was out of the norm. I boosted a couple of times to make sure that everything was on par (making sure wg holds proper boost, no vacum leaks, no loose connections, etc.).
I personally wouldn't go ***** out, but It might be ok to do so.
Old Feb 5, 2003 | 07:50 PM
boosted hybrid's Avatar
Default Re: Turbo Break-In Guidelines (boostedsol)
Turbos are balanced and tested before leaving the factory. They are boost ready as soon as you open the box. Boost away, there isnt any break in period at all.
Old Feb 5, 2003 | 08:18 PM
Phantom's Avatar
I pray that tuner shop didn't get their hands on your car.
Old Feb 5, 2003 | 08:22 PM
swrdply400mrelay's Avatar
Default Re: Turbo Break-In Guidelines (Phantom)
[QUOTE]p.s. My local tuner shop indicated that break-in takes 500 miles, and I should stay beneath 4KRPMs, and never boost.
QUOTE]
That would be true if your engine was brand new and you got the turbo installed at the same time.
Old Feb 6, 2003 | 04:33 AM
B94Cast's Avatar
Default Re: Turbo Break-In Guidelines (swrdply400mrelay)
Thanks for all the input! I have about 200 miles on the new turbo now, and from the sounds of it, I should be fine to go ahead a boost a bit.
Old Feb 6, 2003 | 05:05 AM
intekragsr's Avatar
a little bit...mash that puppy
like everyone said....there is NO breakin period for turbos
Old Feb 6, 2003 | 05:37 AM
PM-Performance's Avatar
Default Re: Turbo Break-In Guidelines (intekragsr)
me and boosted rolled aournd with mine for a couple miles to make sure we had safe a/f for now , from there iv been boosting here and there since the 1st night. its hard to not boost.
Old Feb 6, 2003 | 07:47 AM
B94Cast's Avatar
Default Re: Turbo Break-In Guidelines (itr206)
It is INSANELY hard not to boost!!!
I just want to ensure that I dont let a few miles of no boost craziness cause me issues in the future.
allmotor_dm
Jan 24, 2006 06:07 PM
do what
Sep 27, 2005 08:40 AM
smallttocs
Feb 22, 2003 09:47 AM
falcongsr
Nov 9, 2001 11:34 PM
