Ngk BCPR7ES-11 Sparky Plugs ????
ok so i was told that these are great for turbo hondas, and i plan on slappin on my turbo prob next week on my d16y8, the thing is i have denso iridiums (bout 15000 miles on em), heat range is a 16 which equates to a heat range for denso of 5.33, ngk heat range times 3 equals denso heat range, so the BCPR7ES-11 is a 7 meaning it would be a 21 for denso, now is there ne disadvantage to running these really cold plugs, ive also read about denso not being able to withstand detonation, and destroying the whole motor cuz the electrode broke off, not that i plan to detonate or nething but just in case, i wanna be safe than sorry
does ne one have ne hard facts about my question, opinions are good too
thanks,
chris
thanks,
chris
Re: Ngk BCPR7ES-11 Sparky Plugs ???? (vha27)
That plug is fine. I run that plug in my boosted H22, works great. Heat range of 7 is what you want for boost.
[Modified by sharkcohen, 2:12 AM 2/5/2003]
>>Ngk BCPR7ES-11 <<
You've got the right plugs. FYI if you didn't already know... "Colder" plugs help prevent detonation by having a shorter electrode which doesn't extend into the combustion chamber quite as far as "hotter" plugs. The small amount of extra time it takes the fuel mixture to contact the spark can save your motor.
Re: Ngk BCPR7ES-11 Sparky Plugs ???? (fsp31)
>>Ngk BCPR7ES-11 <<
Re: Ngk BCPR7ES-11 Sparky Plugs ???? (mos)
>>Its not the electrode itself that differs in length, it is the insulator<<
Hold a "5" up next to a "7" paying close attention to the portion that extends into the combustion chamber. The "7" is shorter. I was not aware that the insulation was different, but the amount of plug extending into the combustion chamber is also a key factor.
woah, ic, the higher the number on ngk's the cooler the plug, thought it was the other way around, muh bad, figured a 5 would be cooler than a 7, doh!! ok thanks a lot guys
If you are right, hotter plugs have a higher chance of contact with the piston, which is a bad thing. That does not compute.
http://www.densoiridium.com/heatranges.htm
Re: Ngk BCPR7ES-11 Sparky Plugs ???? (b16ahybrid)
Hotter plugs meaning what the engine calls for will not have a higher chance of piston contact. Runing colder plugs is not standard, so really the so called "hotter" plugs are really standard..
