smoking turbo on a b18b?
Old 02-24-2003, 07:51 PM
ridnmyhonda's Avatar
Default smoking turbo on a b18b?
Ok there is this white smoke that comes from my turbo. My oil return was really small and i had all of it replaced with 1/2" s/s and 1/2" fittings. When the small one was taken off it had oil in it that had burned up and dried and was just sitting there clogging it...so now it's fixed...but it still smokes...i dont have a clue what it could be...seal? any ideas? thanks
Old 02-24-2003, 07:55 PM
Smashback's Avatar
Default Re: smoking turbo on a b18b? (ridnmyhonda)
seals got killed from the feed pressure when the drain clogged...think that's similar to what happened to mine
Old 02-24-2003, 07:56 PM
forgot to say
i took off the piping to the turbo 2 days ago and there was light grease/oil on there...cleaned it off and today 2 days later it's fine...and i took off the piping that goes into the intake manifold and no grease or oil there...
if you cleaned it off the next day you drove it would it start putting stuff back on the inside of it or does this take time?? thanks
Old 02-24-2003, 07:58 PM
Smashback's Avatar
it'll probably take a few days of smoking before you start finding residue in the charge/inducer pipe but who knows...
Old 02-25-2003, 09:53 AM
Foozball26's Avatar
Default Re: smoking turbo on a b18b? (Hatchblack)
well if there was oil in the pipes then I would think you blew the seals.
Is this a new or used turbo? if used how many miles
Old 02-25-2003, 10:51 AM
I Like Boost's Avatar
Default Re: smoking turbo on a b18b? (foozball-26)
If it were the seals that were bad would there only be oil in the charge pipe with no smokeing, or if it were bad seals would it smoke out the exhaust?
Old 02-25-2003, 04:13 PM
Default Re: smoking turbo on a b18b? (IMPULSE B18C-T)
it hasn't been smoking...i think it just burnt off excess oil
Jackzor
06-17-2013 12:41 AM
tvic
09-13-2005 06:33 PM
stikky_p
06-17-2005 09:53 PM
blaze the chemi
05-16-2005 07:21 AM
extrmeboost
07-29-2003 05:33 PM
Quick Reply: smoking turbo on a b18b?
