plugs and fuel
Old Feb 24, 2003 | 06:14 PM
vha27's Avatar
Default plugs and fuel
so i went to my auto class today
i run the hack and have difficulty startings, the tech with 30 years experience sas since im using 93 octane, id have some problems cuz its slower burning, which makes sense, ne opinions on this
also my plugs with less than 150 miles are pretty much fouled, the ring that holds the electrode is a dark soot color althought the electrode is white, im running bpcpr7es -11 gapped to .03, he said try a warmer plug, maybe even stock, why? well weather around here, nj, is cold, so when the car first starts, the block is cold, therefore the plugs (thread area) is cool since it contacts the block, although the electrode is hot (real white color) , uneven heat distribution for the climate right now, maybe the bpcpr7es -11 when the ambient temp is warmer, spring time summer time
what do u guys think, does this makes sense, im gonna try stock plugs tommorow, need some reassurance
chris
Old Feb 24, 2003 | 07:44 PM
vha27's Avatar
Default Re: plugs and fuel (vha27)
buh bump
Old Feb 24, 2003 | 09:47 PM
MotorMatrix.com's Avatar
I am a bad person
the plugs you are using are stage 11 heat range?? if you run a plug thats too cold it will foul. I had to change my stage 8's every week to 10 days.
Old Feb 24, 2003 | 09:51 PM
texan's Avatar
Are you running stock fuel pressure and injector sizing? If not, that's your problem. Not the 93 octane, not the unfouled plugs. Plugs foul when buildup occurs on and directly around the electrode tip & ground strap, the exposed plug body will naturally buildup carbon almost immediately after use.
Old Feb 24, 2003 | 10:02 PM
b16ahybrid's Avatar
Default Re: plugs and fuel (MotorMatrix.com)
That would be a heat range of 7 not 11.
The 11 is the recomended gap.
Old Feb 24, 2003 | 10:14 PM
sharkcohen's Avatar
I wouldn't run the stock heat range with boost.
missionaryrider
Sep 18, 2005 08:36 PM
numotive
Aug 4, 2005 11:26 AM
RTW DC2R
Mar 13, 2004 09:34 PM
Fardoche
Aug 19, 2003 01:52 PM
RJL
Oct 27, 2001 11:44 AM
