1990 Integra LS...turbocharge it or not?
Here is my deal...I have a 1990 LS Integra with 130 K miles. I have my sights set on the DRAG turbo kit which comes with everything I need and pushes a conservative 5-7 PSI. BUT, if I buy this kit will I need to replace my crank shaft or my piston rods? Also, how do I know if my engine can even handle 5-7 PSI of boost? I want the turbo but I dont know if my engine can handle it, and if it can, will I need to replace the crankshaft and piston rods. I plan on rebuilding my engine at 200 K miles, about how much should I expect to pay to have that done.
Guest
Posts: n/a
Re: 1990 Integra LS...turbocharge it or not? (xstalkrx)
Uggh, I had a 90LS that was force fed (and stolen). It was a PITA to install a turbo. **** the Drag kit, go custom. Regardless of what any salesmen tells you, it will be a hack job to install so you might as well go custom and get the parts you want.
Based on my experience I would recommend removing the air conditioning, going to a half wide del Sol dual core radiator, relocating the battery to the trunk, and getting a pusher fan on the front of the radiator. You will have problems getting a filter in there and in getting the compressor outlet charge piping to clear the front crossmember. Maybe having the compressor on the driver side would help this.
Good luck
Good luck
