Anyone know what internal wastegate actuator for 5 or 6psi?
1 Post
I am still working on my setup and almost have everything done, but I need a wastegate that is rated at like 5 or 6psi max to be safe so I can boost low. What cars came with those types of actuators (make, model, year).
I plan on going to the pick n pull yard to pick me some pieces to finish up and I will be on the lookout for those.
TIA
TIA
Re: Anyone know what internal wastegate actuator for 5 or 6psi? (technine)
well, do u have an internal wastegate currently? because if so, u can adjust the length of the rod of the wastegate to have it only boost 5 or 6 psi
good luck!
mike
good luck!
mike
1 Post
Re: Anyone know what internal wastegate actuator for 5 or 6psi? (MikeMAN)
Well, that is the thing, you can only adjust back so much until it becomes a problem with lag and not building boost quick enough to be any good. My current actuator is set @ 10psi and I think it begins to open at 6 or 7psi and then fully opens at 10psi from testing it on a air pump. I heard that 300zx's have 5psi actuators which it fully opens @ 5psi, but unfortunatly their aren't many to choose from at my yard I go to. I need models of cars that have 5-6psi actuators on them so I can run saftely without the chance of overboosting.
Anyone?
Anyone?
yes, I know what internal wastegate acutator opens at 6psi. Saab. get one from a saab t3 setup. as a matter of fact, I have one ready to ship, would you like it?
1 Post
Re: Anyone know what internal wastegate actuator for 5 or 6psi? (vinny)
how much to ship it out? I'm interested, but I need pix because I have to mod it to work with what I got. Thanks vinny. e-mail technical9@yahoo.com
[Modified by technine, 2:38 AM 2/27/2003]
