Timing cover question
Old Feb 27, 2003 | 03:22 PM
B20-T's Avatar
Default Timing cover question
Would a 96 gsr lower timing cover fit on a b20 bottom end?Is there any way i can tell my timing without one?and one more question.Which oil pan gasket do i use for the b20?plmk thanks
Old Feb 27, 2003 | 05:22 PM
Flamenco-T's Avatar
Default Re: Timing cover question (B20-T)
all B series oil pan gasket is the same, they acutally used a P30 part number, but it will work on all B series..
as far as timing cover, you can actually turn the crank to set the no1. piston at TDC, then mark the timing cover where it align with the notch on the crank pulley....
Old Feb 28, 2003 | 04:35 AM
B20-T's Avatar
Default Re: Timing cover question (Flamenco-T)
will the timing cover fit?
xLaziestLa0b0ix
Mar 21, 2012 01:08 AM
z6hatchboy
13
Dec 24, 2007 01:19 PM
SilvrBullet GSR
Nov 20, 2007 12:42 PM
mugenwannabe
Apr 1, 2007 07:03 PM
Brian_92GSR
Aug 19, 2002 07:23 AM
