Which Hondata Should I Get?
Old Feb 27, 2003 | 09:47 AM
Fatty_1775's Avatar
Default Which Hondata Should I Get?
Which Hondata should I get? I have a Revhard Stage 2 Turbo on a second gen jdm B16. Thanks.
Old Feb 27, 2003 | 10:00 AM
Diego Boost's Avatar
Default Re: Which Hondata Should I Get? (Autobot_Killer)
s200 w/ boost
Old Feb 27, 2003 | 11:14 AM
Fatty_1775's Avatar
Default Re: Which Hondata Should I Get? (Diego Boost)
Also, what size injectors should I get? I don't plan on going over 11 psi and I want it to be a daily driver. Thanks.
Old Feb 27, 2003 | 11:18 AM
autoEXturbo's Avatar
s200 w/boost. I'll be running some 900+cc injectors. But i'll be pushing 20+ at the track and 1bar on the street.
Old Feb 27, 2003 | 11:25 AM
avividmemory's Avatar
you'll be straight with 450's for that psi...
Old Feb 27, 2003 | 01:20 PM
Default Re: Which Hondata Should I Get? (SpoolinLS)
Word
Old Feb 27, 2003 | 04:31 PM
DLB1994's Avatar
Default Re: Which Hondata Should I Get? (autoEXturbo)
been time to get away from the **** fmu setup i had the same last year now i have hondata with 758cc and 3bar map sensor
Old Feb 27, 2003 | 04:49 PM
MiraiZ's Avatar
huh? 450cc or 450whp?
Old Feb 27, 2003 | 05:27 PM
ekb18c's Avatar
Default Re: Which Hondata Should I Get? (MiraiZ)
I believe he meant 450cc
Old Feb 28, 2003 | 04:48 AM
Default Re: Which Hondata Should I Get? (DLB1994)
yea, i knew it would need to be done sooner or later. Plus, the motor has so much more potential, i didn't spend this kinda money to stay in the 11's.
Old Feb 28, 2003 | 04:52 AM
MiraiZ's Avatar
Default Re: Which Hondata Should I Get? (ekb18c)
20psi with 450's?!?!?...Isn't that pretty risky?....how much whp are you pushing?
Old Feb 28, 2003 | 04:54 AM
oh no, no. 20 psi on some 900+cc injectors. The most i've taken the 440's up to was about 16psi.
Old Feb 28, 2003 | 06:36 AM
Rory Breaker's Avatar
If you dont plan on ever upgrading it or tuning it yourself, go with the S100 and save a bit of cash.
Id rather spend the extra just in case I get brave in the future.
Old Feb 28, 2003 | 08:04 AM
20lb.teg's Avatar
Default Re: Which Hondata Should I Get? (newgsrdriver)
Well, just buying an S200 system doesn't allow you to tune it your self. YOu still have to have an authorized s200 person with all of the extra stuff!!! IT's Mad $$$ to get the romulator, the extra software, the datalogging, everything adds up and it gets pretty expensive... Well hope this helps.
Later,
Sean C.
Old Feb 28, 2003 | 06:24 PM
DefiantGSR's Avatar
what's the differene between the s100 w/boost and s200 w/boost? Is it that you can get the launch control, full throttle shift, and etc with only the s200?
Old Feb 28, 2003 | 07:53 PM
Default Re: Which Hondata Should I Get? (DefiantGSR)
The s100 system has the following features:
Fits inside the ECU. No external wiring.
Speed limiter removed (if applicable).
Tunable fuel and ignition tables.
Expanded fuel & ignition tables for boost.
Expanded rpm fuel & ignition tables.
A/C cutout.
VTEC control (non user adjustable).
Rev limiter (non user adjustable).
The s200 system has the following features:
A/C cutout.
Shift light.
VTEC control.
Adjustable rev limiter.
Launch control.
Full throttle shift.
Datalogging with HondaLogger software.
ROM Editor tuning software.
[Modified by Diego Boost, 4:54 AM 3/1/2003]
M7EG6
Sep 29, 2008 09:14 PM
spooled b16
May 5, 2003 02:31 PM
HXMan
Dec 24, 2001 11:52 AM
WykidEH
Oct 12, 2001 03:38 AM
