inline fuel pump vafc hack
Old Feb 25, 2003 | 03:54 PM
turbocivic22's Avatar
Default inline fuel pump vafc hack
hi i am currently running the vafc hack plus i am using an inline fuel pump. do u think this will make the car run too rich. i am feeling some hesitation past 5500 rpms at wot. do u think the pump is making the injectors dump to much gas at wot. thanks
Old Feb 25, 2003 | 06:37 PM
tegasaurus's Avatar
Default Re: inline fuel pump vafc hack (turbocivic22)
i've heard that the hole reason that the afc hack is great is because all you haev to do is upgrade the injectors, it gets rid of all the extra (and upgraded) fuel pumps, fmus, etc.
you are probably running very rich, that is why you are feeling the hesitation.
Old Feb 25, 2003 | 08:08 PM
Default Re: inline fuel pump vafc hack (tegasaurus)
yeah thats what i thought im going to remove it and see how it feels thanks
Old Feb 25, 2003 | 09:17 PM
liam821's Avatar
25 Year Member
It also could be that you are running lean. Do you have a EGT gauge? Even an a/f will help.
liam
Old Feb 25, 2003 | 09:48 PM
Default Re: inline fuel pump vafc hack (liam821)
i dont think im running lean. i pulled the plugs to change them and they looked like the car was running really rich. the plug was black and looked fouled
Old Mar 2, 2003 | 09:25 AM
p0gi's Avatar
why not just lower your settings on your afc. set it to like -36 or -37. i found that with a wideband at -35 i run 11.4 afr
aznxphreak
Nov 8, 2003 05:47 PM
BDTURBO
Feb 27, 2003 10:56 AM
Andrew 825SM
Oct 29, 2002 07:35 PM
VTC_CiViC
Sep 17, 2001 11:31 AM
00 Si
Jul 3, 2001 03:13 PM
