Injector wiring ?
Old Feb 27, 2003 | 09:59 AM
boostedsol's Avatar
Default Injector wiring ?
Ok, I have some 440's w/ clips and I need to know what color wire goes to which cylinder. If you are standing infront of your engine w/ the hood popped looking down over the engine, Injector 1 starts closest to the timing belt and injector 4 is closes to the distributor correct? Do the yellow/blk wires go on the outiside of the injector or the inside?
Old Feb 27, 2003 | 10:19 AM
boostaholic's Avatar
Default Re: Injector wiring ? (boostedsol)
Correct, from the timing belt it goes 1-2-3-4 from right to left. For the wires, just match them up with the way the clip attaches to the injectors and just splice and solder the new clips.
Old Feb 27, 2003 | 10:32 AM
boostedsol's Avatar
Default Re: Injector wiring ? (boostaholic)
Ok, well the thing is that there is a yellow/blk wire that goes to each cylinder. The other color wire (brn, blue, yellow, red) goes to a corresponding cylinder as well. They will fit in either slot, so that is why I am asking. I need to know if the yellow/blk wire goes on the outer or inner side where it plugs into the injector.
Old Feb 27, 2003 | 10:37 AM
Sonny's Avatar
Yellow/black is on the tranny side of the engine.
#1 Brown
#2 Red
#3 Blue
#4 Yellow
Sonny
Old Feb 27, 2003 | 10:46 AM
boostedsol's Avatar
Default Re: Injector wiring ? (Sonny)
#1 Brown
#2 Red
#3 Blue
#4 Yellow
Sonny
Ok, so that would mean that starting from cyl 4 (closest to the distribuotr), it should read:
yellow/blk, yellow...yellow/blk, blue...yellow/blk, red...yellow/blk, brown
or would it plug in opposite like this:
starting from cyl 4 (closest to distributor)
yellow, yellow/blk...blue, yellow/blk... red, yellow/blk...brown, yellow/blk
Old Feb 27, 2003 | 11:43 AM
boostedsol's Avatar
so the yellow/blk wire goes on the tranny side of all the injectors?
Old Feb 27, 2003 | 11:51 AM
Sonny's Avatar
Yes
Sonny
Old Feb 27, 2003 | 01:07 PM
boostedsol's Avatar
Thanks for all of your help Sonny.
Old Aug 5, 2004 | 08:07 AM
B18bEK's Avatar
I don't see how this is possible...when i plug my stock injector clips back in...the yellow black sits on the driverside...how is it possible that the yellow black sits on the tranny side..can i get some pics?
Khoi
Old Aug 5, 2004 | 11:16 AM
brkrnu's Avatar
Default Re: Injector wiring ? (B18bEK)
The yellow/black wire only matters when you are using resistors. This is the wire that comes from the ECU with the signal to fire. The other wire is a ground. The resitor should be wired in line with the yellow/black wire.
If you are using saturated injectors it does not matter which wire connects to each side of the clips.
Old Aug 5, 2004 | 12:02 PM
B18bEK's Avatar
Default Re: Injector wiring ? (brkrnu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brkrnu &raquo;</TD></TR><TR><TD CLASS="quote">
If you are using saturated injectors it does not matter which wire connects to each side of the clips.</TD></TR></TABLE>
Awesome! Thanks!!
Dr.Fixit
Jul 19, 2013 10:15 AM
95dc2teg
Dec 16, 2008 02:53 PM
95dc2teg
Dec 15, 2008 08:47 PM
Frozen E
Oct 28, 2004 08:51 AM
ActiveAero
Oct 23, 2004 06:52 PM
